  • Guests: 38
01/18 Noelle (43)
01/18 King_of_Junk (36)
01/18 Ixz (35)
DRSSTC circuit without resonant capacitor
hsieh
Fri Jun 22 2012, 03:32PM Print
hsieh Registered Member #1412 Joined: Thu Mar 27 2008, 04:07PM
I'm trying to build this Link2 coil.After I finished my PCB I want to know if it works or not.I remember that someone on this forum says that a DRSSTC circuit without a resonant capacitor is just a conventional SSTC.So I didn't solder a capacitor and solder a wire instead.
But when I power it up,I cannot see any spark and my variac makes a weird sound.and the insulation of that wire melt.It can light up fluorescent lamp.I tried to change phasing by swap two gate driver chips because everything else is soldered on the PCB.But the fluorescent lamp seems to get darker.
What's wrong?
I use 47N60C3 MOSFET (datasheet: Link2
secondary resonant frequency is 617KHz(I know this might be too high but I don't like big secondaries)
thanks
1340378940 1412 FT0 Imag0309
1340378940 1412 FT0 Imag0310
1340378940 1412 FT0 Imag0311
Ben Solon
Fri Jun 22 2012, 05:19PM
primary feedback doesn't work very well with sstc's. you need high current in the primary circuit to get the ct's to give decent feedback. if you want to run it as a sstc, then find a way to use antenna feedback or secondary base feeback. you can brobably hook it into the input where the ct goes. but if you want it to run as a drsstc, then put in a resonant capacitor, and swap those fets for igbts.
edit: also, dr. dark currents point bellow- in a sstc, you have a primary circuit that is switched to match the ~fres of the secondary. in a drsstc, you have a primary circuit that self resonantes, and you have to match the ~fres of the primary and secondary to the same frequency +- detuning
Fri Jun 22 2012, 05:24PM
yes, the primary circuit will not resonate so you wont get any feedback.
Dr. ISOTOP
Fri Jun 22 2012, 06:05PM
hsieh wrote ...
What's wrong?
thanks
While in theory that feedback circuit should work down to small primary currents (it uses an unloaded CT clamped to the rails by diodes) in reality it probably won't work on an SSTC due to parasitics - scope the primary current and you'll find its probably some garbage triangular waveform.
Also keep in mind the only public schematic I posted is an old one with copper interrupter...the opto driver is still being tweaked (actually, its done tweaking, I just need to update the post).
Daniel Kramnik
Fri Jun 22 2012, 06:39PM
Daniel Kramnik Registered Member #3885 Joined: Sun May 15 2011, 12:47AM
You should invest the $5 or so that the digikey current transformer costs - looks to me like you've got 30 or so turns on a powered iron core, which wouldn't work even if this were set up as a DRSSTC.
hsieh
Sat Jun 23 2012, 01:52AM
So I if install a resonant capacitor,it will work?
I know that the core I use is a high u core(5000 or 10000).I get it from a school lab and someone told me that.Will this work?
Ben Solon
Sat Jun 23 2012, 02:48AM
well, if you dont want to blowout fets, use igbt's. i would give them 10-50 seconds before something catastrophic happens...
Dr. ISOTOP
Sat Jun 23 2012, 03:33AM
hsieh wrote ...
Test the GDT with a signal generator and see!
oneTesla requires a high turns-ratio GDT to minimize current the feedback circuit draws. I had 50:1 in the first version and was experiencing all kinds of horrible effects (feedback resistor catching fire, arcover).
hsieh
Sat Jun 23 2012, 06:38AM
bwang wrote ...
hsieh wrote ...
You mean GDT or primary feedback CT?The turns ratio of my primary feedback CT is 1:130.
And what should I use? MOSEFT or IGBT?I worried that 617KHz is too fast for IGBT so I currently use MOSFET.I have some 40N60 IGBT,will they work?
Dr. ISOTOP
Sat Jun 23 2012, 07:12AM
hsieh wrote ...
bwang wrote ...
hsieh wrote ...
You'll need a new secondary - the fastest IGBT's on the market (Fairchild's field-stop IGBT's) get pretty sad over 400 KHz.
The feedback CT needs a higher turns ratio.
You'll definitely need IGBT's.
