  • Guests: 36
buxtronix (50)
12/26 buxtronix (50)
12/27 Elliott (35)
12/27 Gratitude (40)
3.8 kJ coilgun
Pinkamena
Wed Jun 20 2012, 06:40PM Print
Pinkamena Registered Member #4237 Joined: Tue Nov 29 2011, 02:49PM
Hi guys!
Thoght I'd post some pictures from my coilgun project. It's a 9-stage, 3.8kJ one, and the first coilgun I have ever built. I am using two photogates per stage in order to get full control of when each coil will fire. An IGBT module acts as the main switch, while 9 SCR modules control what coil the current flows to. There's of course more to it, but I know you just want to look at the pretty pictures!
Took this picture today, got started on the plate that the coilgun will be mounted on. The copper bars on each side is for current distribution.
IMG 20120620 184224
L1060311
Two coils that'll become the first stage
L1060310
In the middle of winding one of the coils:
L1060309
Testing a monostable 555-timer. Going to use it to measure the velocity of the projectile.
L1060293
Here's the 555-timer circuit on a breadboard.
L1060302
The IGBT controller:
L1060288
Photogate electronics. I'll need one of these for each stage.
L1060292
If you have any questions, don't hesitate asking! I'll probably update this thread at least a few times a week with new pictures :)
rp181
Wed Jun 20 2012, 09:22PM
Hey,
From what I understand, you have a central capacitor bank, and IGBT switch, and 9 SCR's to direct current to the correct coil. Why not split up the bank and use the SCR's directly? If you want control of the pulse and turn it off when the second photogate is triggered, take a look at the V switch method:
Pinkamena
Wed Jun 20 2012, 09:44PM
I was initially going to split the cap bank up in smaller units, but more experienced coilgun builders said that it was a bad idea.
Forty
Fri Jun 22 2012, 04:40PM
Is it just me or are there big gaps between your coil layers? You shouldn't need any extra insulation unless your charging your caps in series
I just got an almost identical sized capacitor bank in the mail today O_o 12x 3900uf 400v = 3.744kJ
(+ 4x 2200uF 450v, but they seem light and need tested)
edit: Oh and a fun conversion i made up: Joules to stories dropped by 16lb bowling ball: divide by 235
Pinkamena
Sat Jun 23 2012, 03:00PM
There is a layer of masking tape between each layer of wire. This so that the coil won't unravel when I Remove it from the winding rig, not for insulation. The tape is pretty thin, so it does not have a big negative effect on the coil. Great to hear about your cap bank!
Saz43
Sat Jun 23 2012, 03:57PM
Pinkamena wrote ...
I don't think there's any logic to this. You don't get any advantage by doing it this way, and it makes calculations much more difficult. Notice that the people who claim to be experts and recommend doing it this way have never actually built one... that being said, I'm very interested to see how it works out in your case. Please give us lots of updates!
Question: If you're using SCRs to trigger the individual coils, how do you plan to turn them off at the right time? Is that what the IGBT is for?
Nice work! It's good to see someone else is putting serious work into a coilgun!
Forty
Sun Jun 24 2012, 05:31AM
hmm. To me it looks like your hand is visible through the layers.. Oh well.
Anyways, have you tried using liquid super glue to bind the layers together? I've had great success using it with 16awg wire. Allows the windings to be as dense as possible too.
I can't picture how you're going to get one IGBT to switch all the coils individually with separate banks. Have a sketch of the circuit or care to explain it?
I can only think of three ways of doing it (excluding v-switch stuff):
1. separate banks with an SCR or IGBT per coil
2. one bank with an IGBT per coil
3. one bank with an IGBT to control on/off and an SCR per coil
Oh and where are you getting your SCRs from? I need to find some cheap ones as well.
Tetris
Sun Jun 24 2012, 07:01AM
Ooo that looks nice
Pinkamena
Fri Jun 29 2012, 04:03PM
Saz43 wrote ...
Pinkamena wrote ...
Honestly, keeping the cap bank in one piece saved me a lot of time writing my simulation.
A single bank for each stage would require me to design the coil so it would use all the energy in the bank on the time it took the projectile to pass through. Not only would the force be varying and relatively difficult to simulate, but the turns/layers configuration for this would likely not be the most effective either. Keeping the cap bank in one piece will allow me to vary the amount of energy per stage, not being bound to a set amount. It literally takes the stored energy out of the equation when finding the most effective coil configuration since I have no lower nor upper limit (within reason of course) for the energy consumption per coil, only for the 9 coils together. The force per stage will also be nearly constant, so calculating the work per stage is much simpler.
Regarding the SCR question, you are correct. The IGBT and one of the SCRs will be turned on at a time. So the IGBT will turn on and off 9 times per shot, while each SCR will only turn on and off once. And thanks for the kind words! Your own coilgun projects have really inspired me.
Forty wrote ...
Yes, I did try using super glue first, but the two kinds I had available didn't work... So I used the next best thing, tape! And about the switching method, see my reply to Saz :) I do not have any schematics for the switching system unfortunately. And I bought my SCRs from ebay I think. They can't take very high current though, so I gotta put some in series for the last 4 coils which will get a current way up in the >5kA area.
Pinkamena
Mon Jul 02 2012, 07:19PM
More pictures! I finally finished the first stage and got it mounted. The control panel is also coming along nicely.
About the iron sleeve: It's made from polyester and iron powder. I used a ratio of about 4 parts polyester, 6 parts iron powder. I wish I could have used less polyester. I first tried a ratio of 1/4, but that just made the iron powder sort of a damp paste that could be molded but not poured into the forms. I used soft rubber sheets to make the forms, and covered everything with vaseline so it wouldn't stick. Worked like a charm.
IMG 20120702 135207
Stuffed the two pre-wound coils into the sleeve. It's bloody heavy!
IMG 20120702 151735
IMG 20120702 151742
IMG 20120702 154404
Also, projectile and control panel (not finished)
IMG 20120630 193821 2
There's two compartments. The lower is for the photogate electronics, while the upper is for everything else.
IMG 20120630 193940
Here's the projectile. It weighs 75 grams, and is made from a 1/2" steel rod of grade EN1A.
IMG 20120630 185523
