  • Guests: 48
01/18 Noelle (43)
01/18 King_of_Junk (36)
01/18 Ixz (35)
Mini Full Wave MOT VTTC 811a Coil
TwirlyWhirly555
Fri Jun 15 2012, 02:38PM Print
TwirlyWhirly555 Registered Member #4104 Joined: Fri Sept 23 2011, 06:54PM
Hi
My new best VTTC i have made :D
Specs are -
Primary 30 turns
feedback 15 turns
grid resistor 3.3Kohm
grid capacitor 1.4 nF
tank capacitor 740 pF
Supply MOT Full wave rectified + 1uF smoothing capacitor .
secondary topload is base from a small coke can .
Secondary is 9cm total Hight , 5cm diamiter and has around 6cm worth of windings with 0.125mm wire and then coverd in insulation tape as it all i have on hand . Output arc is just above 4" long ( 10 - 11cm Long ) on a previouse secondary that was abit taller i got 13cm arcs . Anode heating is there but not that bad . probably could do with more tuning .
But i love the bushy output from full wave supply :D and as this is my second coil im really happy with results .
Link2 here a quick video of it running .
1339771109 4104 FT0 Sam 0537
1339771109 4104 FT0 Sam 0540
1339771109 4104 FT0 Sam 0545
1339771109 4104 FT0 Sam 0546
Patric
Fri Jun 15 2012, 03:30PM
Patric Registered Member #2899 Joined: Wed Jun 02 2010, 06:31PM
Beautiful result! Is the 811a not turning red?
TwirlyWhirly555
Fri Jun 15 2012, 03:36PM
Patric wrote ...
Thanks :) , anode will turn a light red after 15 seconds using this secondary befor i remade secondary it would run cooler probaly need abit of tuning again , at full power main isseue is secondary heating , under halfwave operation it wasnt not that bad . but CW it gets hot fast .
Power input is 4.5 amps @ 230 V so just over 1Kw In .
Patric
Sat Jun 16 2012, 08:01PM
This is my coil. The regulation works really perfect, the output of the MOT can be regulated between 1750V (tube light red) and 1000 V (tube can work for hours).
1339876856 2899 FT140119 Tesla811adef
TwirlyWhirly555
Sat Jun 16 2012, 08:04PM
Nice :) , I just use my variac to addjust mine . I plan to maker a wider primary and retune and then interupt coil with a mosfet in cathode - ground connection .
Link2 Video with NaCl on electrode .
Mon Jun 18 2012, 09:08AM
Very nice coil !
I just built one with specs close to yours, but running halfwave, and I also have problems with secondary and tube heating at full power ...
TwirlyWhirly555
Mon Jun 18 2012, 12:21PM
PhilGood wrote ...
Very nice coil !
Hi ,
Nice Coil There :) , I have changed mine back to halfwave as running full wave i was getting arc overs from primary to secondary .
I now pulse the coil on and off via a mosfet in cathode - ground connection and i have no anode redding and secondary only gets warm :) and it still pushes 4" Arcs :D
Half Wave Pused Link2
Mon Jun 18 2012, 12:53PM
Great result !
Good to hear that :)
I think I'm gonna build a staccato very soon !
TwirlyWhirly555
Mon Jun 18 2012, 03:45PM
PhilGood wrote ...
Great result !
Thanks :D , Yeah staccato is great little thing , im just using a single 555 timer and mosfet to puls coil , works great .
Link2 fast pulsing with strontium nitarte on breakout .
