  • Guests: 46
Forty (38)
12/11 Forty (38)
12/13 williamn (48)
12/13 ReddyK (57)
Neat Full bridge IC
Adam Munich
Wed Jun 13 2012, 08:16PM Print
While thinking of a way to make a super-compact, 22.4V > 75kV @ 1.5kW power source I stumbled across this rather awesome full bridge IC from intersil.
I've ordered a few of them; will eventually let everyone know if they are any good. smile
tsteele93
Fri Jun 22 2012, 01:00AM
tsteele93 Registered Member #5413 Joined: Thu Jun 21 2012, 01:16PM
How come you are over a million and a half miles farther from Sol than the rest of us?
Josh Campbell
Fri Jun 22 2012, 02:30AM
Josh Campbell Registered Member #5258 Joined: Sun Jun 10 2012, 10:15PM
Very cool, definitely interested in hearing your analysis of this controller.
Adam Munich
Sun Jul 01 2012, 03:21AM
Finally got this IC soldered into DIP form, hopefully I get around to playing with it.
The upper drives are not isolated and fixed at 50% duty cycle, likely they are designed for use with GDTs. All adjustments are done by varying the lower side duty cycle (something Steve did in his lighting gun...?).
Also has synchronous rectifier outputs.
Page 8 Link2
