  • Guests: 47
Two DRSSTC tuning questions
Wed Jun 13 2012, 08:12PM Print
Hi,
As I've never used delay compensation circuits before, this was of no concern to me, because the IGBTs were always switching late tongue Is it best to tune the switching transitions a bit after, bit before or exactly at the current zero crossing?
And the second question, with small ultrafast IGBTs which have the turn-off time in the ~100-150ns range, is a dead time needed or will a simple resistor-diode combination in series with the gate do the trick? I could check this by measuring the power consumption with no load, but i don't know if the cross conduction doesn't appear only with a load.
Wed Jun 13 2012, 10:24PM
I adjusted the delay while looking at the H-bridge output voltage on a scope. There's a (quite narrow) setting where all of the ringing disappears and the waveform looks perfect. That's where I set mine. smile I think it corresponds to switching slightly before the zero crossings.
My driver has adjustable deadtime, but when using the Fairchild miniblocks, it worked fine with the deadtime set to minimum, about 100ns. I think it would still work at 0ns, and even if it didn't, you could easily add 100ns of deadtime with the resistor and diode.
Thu Jun 14 2012, 08:59AM
Thanks wink
Thu Jun 14 2012, 10:09PM
Just one more question, is it really bad if the interrupter is not synchronised to turn off at current zero crossing? When running long ON times and low peak currents...
