  • Guests: 53
IRG4PC50UD top current question
Intra
Wed Jun 13 2012, 12:10AM Print
Intra Registered Member #2694 Joined: Mon Feb 22 2010, 11:52PM
Hi all
I'll going to find a top limit of IRG4PC50UD bridge current and will be use UD2.1b, 0,3uF 6kV CDE MMC, 4 turn primary, coupling k=0.18 and 100kHz secondary. With two notes poly from 30Hz to 1kHz freq, which top primary current can be set?
Ben Solon
Wed Jun 13 2012, 02:08AM
there's no way to tell until you test it. it depends on too many variables. but if you know how much power you want to put in(or streamer length) you can get a general range. but there have been a few coils using this igbt that could hit four feet+ with it, which is somewhere in the 6-8 hundred amps. again, an extremely rough guess.
