  • Guests: 44
Tesla Coil Specs
Chip Fixes
Mon Jun 11 2012, 11:41PM Print
Ah my friend bought 1,600 feet of #30 awg magnet wire and wants to build a Tesla coil with it. Neither of us are picky about the design and we pretty much just want to start with the secondary coil and work backwards from there. So any advice (SSTC vs SGTC etc.) is appreciated.
What we do want:
- Use all, or almost all of the magnet wire
- Big discharges
- Audio Modulated
Also, neither of us own an NST so we'd like to run it off of mains (120v) or Microwave Oven Transformer(s).
I have 3 Mots, one of them with the primary coil knocked out.
Ben Solon
Mon Jun 11 2012, 11:50PM
well, you cant play music with a sgtc, but a vttc can with a high voltage primary circuit. though i hav'nt seen much in taht area. for a first tc, your best bet would be in a mains powered sstc, because a drsstc is not only a pain with igbt chunks flying around when you screw up, but you also need extremely precise microcontrollers(16bit timers) and some really good programming skills to get it to not blow up even more igbts. look around, sstc's are all over the place, and not hard to build at all.
Chip Fixes
Tue Jun 12 2012, 01:41AM
Alright, thanks! SSTC it is!
kwinchee
Tue Jun 12 2012, 11:59AM
kwinchee Registered Member #1287 Joined: Mon Feb 04 2008, 11:03AM
Good luck, you mite need it... :P
brandon3055
Tue Jun 12 2012, 12:36PM
I think you can audio modulate an SGTC if you use a triggered spark gap
Hazmatt_(The Underdog)
Thu Jun 14 2012, 12:56AM
300 - 400 W of input power for a 30 awg coil should be fine, aka low power stuff,
But 2 mots and you're lookin at 3kw, which would require something like 26 or 24 awg.
I think you're going to need heavier wire.
Dri0m
Thu Jun 14 2012, 05:22AM
Dri0m Registered Member #4497 Joined: Thu Apr 19 2012, 12:53PM
Destroyer of mosfets wrote ...
Or you can use spark gap that can change its electrode distance (stepper motors maybe) to change frequency of arcs, then it will play music :)
