  • Guests: 52
RoV IW3IPD (63)
01/12 RoV IW3IPD (63)
The truth about autism?
Thu Jun 07 2012, 08:48PM Print
I wouldnt normally post links to this site but there are numerous alternate sources including BBC News and the original papers.
Essentially the issues with fertility drugs getting into the water supply are 100 times worse with antidepressants.
Perhaps this is why autism has increased in recent years, after all the developing brain is much more sensitive than those who take these drugs as a "cure" for depression etc.
I wouldn't be at all surprised if it is found that schizophrenia in adulthood as well as OCD and ADHD can be linked back to early exposure to these compounds.
Hate to say it but the more medicated we become the worse the contamination gets.
Its a side effect of high population density which could go a long way towards explaining how mental illness increases in large cities where waste water is routinely reprocessed (ie London)
Also, a regular water filter won't help (much), these compounds get through pretty much anything.
Only way to stop them would be distillation which uses too much power to be practical.
-A
Chris Russell
Fri Jun 08 2012, 02:52AM
Chris Russell ... not Russel!
No. No no no. From the article:
Multiple studies have found a direct link between the use of the mercury based preservative thimerosal and a dramatic rise in cases of autism.
This is incorrect, irresponsible, and dangerous.
No good can come of this article, or a discussion about it.
