  • Guests: 62
  • Members: 1
01/23 GimpyJoe (36)
01/24 OnFire (64)
01/25 Evgenij (60)
Complete 9.4kJ railgun system for sale
rp181
Wed Jun 06 2012, 09:37PM Print
I've had my fill of pulse energy, so time to move on!
Included is the following:
-Bank of 30 400v 3900uf capacitors, with 1/4" thick aluminum bus bars and 00 AWG Copper cables.
-Voltage tripler to run from 120v mains, capable of 450v max output.
-4x 50ohm 250W resistors used in parallel to serve as a current limiter to the tripler
-2x 1000ohm 300W resistors to discharge the bank (In need of a better switch)
-Complete injector with quick connect, and a schrader adapter w/ pressure gauge. Uses a 3/4" quick exhaust valve (Makes for a powerful pneumatic cannon in itself).
-500v digital (blue) voltage meter
-CNC machined 2 piece Garolite G11 railgun body w/ 24 SS bolts.
-One set of unused rails, and a set of teflon rails for the injector portion
-~20 U tail projectiles
I will not include the base, as that would add to shipping costs when I simply used a $10 piece of wood from home depot.
Expect shipping to be around $150. I am open to any reasonable offers and trades (test equipment). I am willing to part out if no one wants the whole thing.
RpVsq
La50q
L9vcK
