  • Guests: 40
IGBT current ratings
zzz_julian_zzz
Sun Jun 03 2012, 12:01AM Print
Hi,
I would like to know what will be the considering factors about IGBT in the current rating sections,
IS the current continuous of IGBT are the one should we look for higher ratings? or
IS the current pulsed of the IGBT we should be looking at?
What if it has low pulsed rating like (150 A)
and high continuous @25 degree = 100A & @100 degree = 75A ?
is this a good IGBT?
Or high pulsed rating like (300 A)
and low continuous @25 = 60A & @100 =35A
Also, are the physical packaging(body) of the IGBT are another factor to consider? I've seen some more powerful IGBT in TO-220 than in TO-247.. and powerful TO-247 than in SOT-77B bricks.
all of this if I want to run my drsstc 800 amps reliably..
Thanks..
Dr. ISOTOP
Sun Jun 03 2012, 03:34AM
The pulsed rating matters more.
However, keep in mind that different ratings from different manufacturers/different product lines are not comparable.
For reliable 800A operation, I'd use CM300 bricks - 800A is only a little over their pulsed rating.
EDIT: Random thoughts: I've been fiddling with this thing for the past couple days, and finally experienced my first real (non-human-error) bridge failure. It seems like the FGH40N60SMDF does not like running past 300A. This is a far cry from the legendary HGT1N40N60A4D, which could run 1000A without failing frown
(this failure was at 60uS on time, 340V bus, during continuous ground strikes).
Perhaps this is the price to be paid for the improved switching times of field-stop IGBT's? or perhaps manufacturers are getting cheap and not putting as much silicon into the die as they did in the good ol' days.
Sun Jun 03 2012, 10:51AM
Remember that the number different manufactures put before the "N" letter always means a different rating... With the xxN60A4D types, it is the actual output current they can swich in CW operation including switching losses, but often it is just the DC current rating and the actual operating current is lower.
Dr. ISOTOP
Sun Jun 03 2012, 02:31PM
Dr. Dark Current wrote ...
Coiler go by the absolute ``how far can i push it before it goes boom?'' rating though tongue which sadly doesn't appear on the datasheet.
dude_500
Mon Jun 04 2012, 08:39PM
dude_500 Registered Member #2288 Joined: Wed Aug 12 2009, 10:42PM
bwang wrote ...
Has anyone done the I^2T calculation for their coils as they go boom? It's quite possible that's actually a decent explosion limit to go by for coiling.
Goodchild
Tue Jun 05 2012, 06:34AM
Ok I'm going to try and clear something up that I didn't understand for a long time about IGBT and power transistor ratings in general. The pulsed and continuous rating of power transistors is dictated by one thing, heat...
For continuous and pulsed operation the die has to be able to constantly transfer and dissipate the power that is dropped across it. For IGBTs this is dictated by the foreword voltage drop from collector to emitter (also called the saturation voltage) much like a diode. Usually on the order of ~2.5v for a lot of larger IGBTs but it also can be as high as 5V or more. Most hobbyist overlook this value in the datasheet when selecting a device. For example the CM600HA-24H has a Vce of 2.5V if I remember correctly so if you are pushing say 1000A the device is going to dissipate 1000A * 2.5V = 2.5Kw of heat. For a DR this is usually not to bad because at DR duty this averages to maybe 300W at the most. The voltage drop is fixed and doesn't change much with current making IGBTs ideal for pulsing with larger currents.
The observant viewer of the datasheet will also note a thermal resistance from die to case rating usually in C/W. This rating tells you how well your particular package can transfer heat from the die to the outside of the package. They will usually also give you a nice graph plotting out thermal impedance over some key operating values of the IGBT in question. A lot of datasheet will even do the hard work for you and give you continuous dissipation rating of the device. This is usually the largest Vce * rated current. For the CM600HA-24H example this is 4.2Kw.
Knowing these values you can get a good idea of how well your device will perform under pulsed or continuous operation. Obviously the IGBT can handle higher pulsed currents because you can give the IGBT more time to get the heat out of the die. Also the dissipation of the the diode and switching losses with also add to the total heat, but that is another hole can of worms.
Bottom line is if you heat the die up to much it fails and you are left with a hunk of useless silicon.
There are also a bunch of good papers on this if you do a quick search on google.
Hope this clears it up a bit. wink
Tue Jun 05 2012, 10:42AM
I think the pulsed rating may have something to do with other things as well such as bonding wire cross section, current distribution in the die, possibly thermal shocks and "temperature ripple" at the interrupter frequency, and turn off SOA.
Goodchild
Tue Jun 05 2012, 02:23PM
But all of those thing are about heat in the device and getting it out wink That's the only point I'm trying to make. You can get a great idea of what your IGBT will do before you run it. Untimely you will know how well it works by testing in the real circuit.
Dr. ISOTOP
Tue Jun 05 2012, 05:33PM
Goodchild wrote ...
While I agree that heating has a great deal to do with how long a transistor lasts, aren't there also pure device-physics limitations on how much current a given die can carry?
I don't really know enough semiconductor physics to say for certain though...
Goodchild
Wed Jun 06 2012, 03:14AM
Well stop and think about it for a sec. What actually kills the die? The answer is once again our old friend heat. I know it seems like there should be more to it than that but there really isn't. Thing about it in simple terms like a wire. The only way you are going to get that wire to fail is to push enough power through it to get it to melt and fail. If you are able to remove the heat from the wire as quick as you put it in then the wire will never heat up and never fail simple physics. shades
