  • Guests: 81
Jyardana (41)
Gunboat (72)
09/17 Jyardana (41)
09/17 Gunboat (72)
09/19 raff (48)
Mystery
ZakWolf
Thu May 24 2012, 12:15AM Print
Awhile back a made a thread trying to debug a PCB plasma speaker i made with no solution, I put it away for a later day.
circuit --- Link2
old thread--- Link2
Well today is the day, I was looking at it and after checking the circuit and traces over and over and over for about a year i cannot find any errors.
I was wondering if someone with more knowledge could give me a possible cause with the given symptoms.
IC stays cool when low voltage side is on. (15v)
Mosfet's are cool and in fact im sure are not turning on.
No current draw from the Mosfet side.
also this is my second make of this, the first one still works and hasnt had any issues.
-zak
Thu May 24 2012, 09:36AM
Unless you provide some measurements from a oscilloscope, nobody will be able to help you.
What you just said is "There is gas in my tank, but the car wont move, I think the engine is not running. What is wrong with my car?"
Tetris
Thu May 24 2012, 04:17PM
You sure a part isn't blown? I've had that happen: WTF IS WRONG WITH MY CIRCUIT!!! Oh the 555 and LED are both blown. So check your components, they might be blown.
Thu May 24 2012, 08:09PM
Same here, except mine failed due to the PIC getting its MCLR line fried and "half worked".
That was a pig to diagnose, had to resort to ordering a new chip and comparing it side by side before the problem showed itself.
Neet Studio
Thu May 24 2012, 09:34PM
Neet Studio Registered Member #4037 Joined: Fri Jul 29 2011, 03:13PM
Expecting someone on the internet to remotely debugging hardware without being to observe the waveforms/symptoms does not work. You might have better luck asking psychics as that's exactly what you are asking us to do.
A binary "does not work" only carries a single bit of information. At best we might tell you stories or how we would try to diagnostic such a problem or we "make shit up" to compensate for lack of input.
Have you try to follow the signal to see at which point it stops being not what you have expected? This assumes that you have an understanding of how the circuit work or run a simulation to get an idea what the results looks like.
Also have a clear schematic would help. My mind do not convert a pictorial layout of packages into an annotated form called a "schematic" with proper symbols. In doing so, it might also let you see where the signal is going and how it is different from the original form.
ZakWolf
Thu May 24 2012, 10:21PM
thanks guys, to bad i dont have a oscilloscope, i was just wondering if there were any common bugs that have the same symptoms as mine. I guess i will rebuild it.
brandon3055
Fri May 25 2012, 10:16AM
If you have an identical circuit that works can't you just do a side by side comparison to see what's different
Ben Solon
Fri May 25 2012, 12:45PM
Even with no oscilloscope, you can see where voltage is an current flows with any mm. First see that there is voltage wherever it should be. If it all checks out, look to the mosfets gates. Are they receiving gate drive? An led or small speaker with a series resistor will tell you it it's pulsing. By no means can you get any waveform, but it'll let you know what's going on. If the gates are not receiving signals, work you way down the line towards the ic. Crude, I know, but it's all you can do with no oscilloscope.
