  • Guests: 50
Liquid fluoride core thorium vortex reactor?
Wed May 23 2012, 10:54PM Print
Hi all.
has anyone else heard of this approach?
It seems that one possible way to get reasonable energy densities from a thorium reactor is to dispense with the solid core entirely and use thorium 232 as hexafluoride.
This is then spun up to high speeds in a spherical beryllium cased reactor containing a counter-rotating inner beryllium core with the heat exchangers and coolant, which resembles the "Earth Core simulator" and then bombarded from one or both ends with neutrons from a linac.
The main advantage of this approach is that because the fluoride salt is spinning it can be evenly distributed and cooled via directed liquid lead/bismuth.
As the heavy thorium salts would end up in a thin layer the energy density could be very high indeed but retaining the ability to shut down the reactor by cutting off the linac's drive.
Sound feasible?
-A
Chip Fixes
Thu May 24 2012, 02:53AM
Sounds awesome! Sounds expensive and complicated as well...
Tetris
Thu May 24 2012, 04:19PM
Sounds like an awesome science experiment/demo but it doesn't sound practical.
2Spoons
Thu May 24 2012, 11:03PM
"Spherical beryllium casing" immediately brings to mind the movie "Galaxy Quest". One of my favorites.
