  • Guests: 59
Choosing grid leak resistor for VTTC
megabyte
Mon May 21 2012, 03:09AM Print
megabyte Registered Member #4953 Joined: Sat May 19 2012, 11:56PM
Hi Guys, first post here.
I'm building a Dual 811A VTTC based on Steve's FAQ (here) and I have a few questions about selecting the grid leak resistor. I currently have two 1K, 100W wirewound rheostats (pictured below) that I was going to connect in series, but I'm not sure if they will do.
1337569656 4953 FT0 Rheostat
1. Steve's schematic uses a 500R resistor, but most others out there use anywhere from 2K to 5K ohms. This is a big difference and I was wondering what's right for a dual 811A coil (with or without staccato, with or without voltage doubler on the MOT)?
2. I am worried about the inductance of the rheostats since they have a large diameter and large number of turns. Is this likely to cause problems, or will the Q be too low to worry about due to their resistance?
Thanks in advance,
Mick.
Mon May 21 2012, 08:21AM
1. I am pretty sure 500 ohms is too low, I would say the optimal resistance for 2 tubes would be closer to 5k (10k for one, after all its a pretty small tube).
2. The inductance does not matter as the resistor sees neary DC voltage.
megabyte
Mon May 21 2012, 08:43AM
Thanks Doc,
I'll look into other solutions for the grid feedback resistor then because my rheostats will only be 2K max. Good to know that inductance isn't much of a concern.
Cheers,
Mick.
Mon May 21 2012, 10:32AM
I my dual 811A VTTC ( Link2 ) I had a adjustable grid leak resistor setup so I could change between 500R, 1K, 1K5, 2K, 2K5.
All settings are viable for a dual 811A VTTC and gives you more parameters to play with when optimizing your coil.
Luceš
Wed May 23 2012, 02:11PM
Luceš Registered Member #4108 Joined: Sun Sept 25 2011, 11:43PM
For my gu-81m vttc I used 2 75watt 120v light bulbs in series.
