  • Guests: 56
Please tell me if this schematic for Full-Bridge DRSSTC could work
Dédé!
Thu May 17 2012, 02:37PM Print
Dédé! Registered Member #4932 Joined: Thu May 17 2012, 01:42PM
Greatings Coilers,
I'm new here and would like to know if the following schematic of a drsstc could work efficiently.
1337265081 4932 FT0 Full Bridge Drsstc
If it doesn't work optimal, you can add a post and tell me what i should change.
I know this schematic looks a lot like Ericgoodchild's schematic, but i did make a few changes.
Greatings,
Dehim Verveen
PS. I forgot to tell in my mail to forum at 4hv.org that I'm not really English but i can speak quite well.
Thu May 24 2012, 11:56AM
Hi,
the SPP15N60 is a MOSFET with a relatively high RDS on (for a DRSSTC duty), will work just for low powers or long bursts with low current. The external diodes are useless as the internal ones in the FETs turn on anyway. Use 20 volt TVS on the gates.
I would suggest replacing the FETs with IGBTs, even similar priced ones will push much higher peak currents than the fets.
