  • Guests: 62
where do you get your power
brandon3055
Thu May 17 2012, 08:24AM Print
Hi all this is a question to all of you who build very large c tc's or anything that uses a lot of current because just running 4 MOT's can draw up to 4kw which is over the max power for a standard wall outlet so where do you plug in?
Thu May 17 2012, 08:25AM
Four standard power sockets ?
brandon3055
Thu May 17 2012, 08:59AM
Sulaiman wrote ...
Regular 240 outlet which unless imistaken are rated for 10amps max
Thu May 17 2012, 09:13AM
In Denmark all households have 3 phased 25A fused from the road side box.
Inside the house there is always as minimum a 3 phase 16A outlet for stove, ovens etc.
So inside a Danish house...
3 phased we can draw 11kW
2 phased we can draw 6.4kW
1 phased + neutral we can draw 2.3kW
Most garages, workshops, public places etc got 3 phased 32A outlets and up.
brandon3055
Thu May 17 2012, 09:47AM
Well I guess when you think about it each outlet in your house Dosent have its own line to the meter box (unless it's a proper 15A 20A or larger outle) so a lot of the outlets will be piggy backed so if each one can handle 10A then the main line should be able to handle a bit more then 10A as long as their are no other large loads on the same line tight?
And if not that's what the circuit bracker is for
TwirlyWhirly555
Thu May 17 2012, 11:17AM
TwirlyWhirly555 Registered Member #4104 Joined: Fri Sept 23 2011, 06:54PM
In the Uk , Plugs are 13A fuse protected and the socket ring final circuit is backed by 32A breaker .
Thu May 17 2012, 03:28PM
TwirlyWhirly555 wrote ...
What this means in practice is, by replacing the plug fuse with a piece of 1/4" copper pipe, you can get 32A at 240V out of a UK wall socket for a short time, which has always been enough for me! smile
In fact, I found that the 13A plug fuse is pretty tough and would pass 30A for long enough to run a Tesla coil. I've popped the 32A breaker many times, but I think I only ever blew one plug fuse.
My workplace has a high voltage lab with a 3 phase, 400V, 63A feed, but I haven't built anything big enough to take advantage of it. Yet.
The big DRSSTCs seem to run off a 240V single phase supply (which is available in the USA for bigger appliances) and the really big ones, like Steve Ward's Gigantor, need 480V 3 phase. I believe Gigantor needs about 30kW of power.
Dr. Slack
Thu May 17 2012, 06:49PM
As the UK ring main is connected back by two 2.5mm2 cores to the 32A breaker, I have in the past drawn power from two paralleled 13A plugs. Now there's obviously a hazard in directly paralleling two plugs. If you plug one in, the pins of the other are live, not good. What I did was plug two unwired 13A plugs into a double socket, then glue a bit of wood across their backs, to get the spacing right. I now have a 6 pin plug rated at 26A, which physically cannot leave live pins sticking out. Each plug was then wired with equal lengths (about 3m) of 1.5mm2 flex, and then paralleled into a 32A "commando" socket. The idea was that the series resistance of these two longish thinnish wires would help to balance the plug currents. It helps to choose a double socket that is symmetrically placed on the ring, to equalise the resistances and so currents back to the breaker.
However my preferred route is to tap straight into the mains, after the meter and master 100A fuse, but before the consumer breaker unit. YMMV, but my consumer unit is connected back to the meter by a neat choc-block affair, which appears to have been designed to allow (relatively) safe live working, and is obviously there to enable the unit to be disconnected without breaking the power from the meter. I have a small one fuse box and 32A commando socket that gets wired into there whenever I want some juice. Fused at 40A, because I really don't want to lose power to the whole house if I screw up.
Needless to say, this was a while ago. I haven't done this since "part P" electrical regulations came in, honest.
Fri May 18 2012, 09:27AM
For those non-UK readers mystified by this talk of commando sockets and ring mains:
Neither exists in the USA as far as I know.
Dr. Slack
Sun Jun 03 2012, 04:03PM
Commando plug and socket, and fuse pictured here. Note the socket has been temporarily wired as a 6A to 32A adapter, to enable the powering up of low powered stuff, but it's only a screwdriver away from being wired back as a full 32A socket.
These items now appearing in the For Sale thread, if anyone is interested
1338739121 72 FT1630 Fuse Box Commando
