  • Guests: 60
ZVS IRFP250 catastrophic failure
TS00
Sat May 12 2012, 11:02AM Print
TS00 Registered Member #4860 Joined: Fri May 11 2012, 04:42PM
Hi all,
I've just built my first ZVS. It worked great for a few minutes, producing 6-7cm arcs at 24V (far better and hotter than the 555 driver did on the same flyback). After a few minutes, while drawing an arc, both the FETs went bang. It was sequential, one went immediately followed by the other.
They both have big craters just above the source pin. The heatsink was barely warm.
Initially I though that perhaps the capacitor (a 0.68uF 400V MKT) had gone open-circuit, causing the failure. But the capacitor tests fine.
My only other suspicion is that I had the inductor too close to the flyback (around 3cm away), which resulted in the toroid saturating. Could that have been it?
Any other ideas on what may have caused the failure?
Thanks!
Wolfram
Sat May 12 2012, 11:55AM
We need more info about your setup. What sort of core is the inductor wound on?
TS00
Sat May 12 2012, 12:19PM
Wolfram wrote ...
Hi Wolfram,
The inductor is wound around a 1 inch ferrite ring. It has 20 windings of PVC insulated multi-strand (32/0.2mm, 1mm2 conductor area), and measures at 150uH. I would have used 16 gauge enamelled copper wire, but I don't have any to hand.
The rest of the circuit is exactly as per the standard Mazilli circuit.
Antonio
Sat May 12 2012, 02:51PM
The basic circuit is unsafe, even if well built. If for some reason, as excessive load (arcs), core saturation (arcs), etc. the oscillation stops, it self-destructs immediately. Something added to limit the input current (at least a fuse) or the output load (series resistor) may extend the life of the circuit for some time.
TS00
Sat May 12 2012, 02:57PM
Antonio wrote ...
So is it common for the FETs to explode? Do other people running this circuit experience this?
Inducktion
Sat May 12 2012, 03:28PM
Yes; the ZVS driver has issues with exploding if something causes one of the transistors to latch on...it then steals all of the current from the other mosfet, and then explodes from overcurrent.
The other mosfet will then explode after.
Why? If you look at the way the circuit feedback is designed, and the way the gate driving is, you'll notice that if you didn't have the resonant circuit there, the mosfets would be on. Completely and utterly on.
So if for any reason the resonant circuit stops oscillating or "leaves" the circuit the mosfets will explode from overcurrent.
TS00
Sat May 12 2012, 03:30PM
Ok, that makes sense - is there a successful solution that people are using with this circuit?
Platinum
Sat May 12 2012, 06:31PM
It's not a good circuit in the first place, every ZVS in the end will blow.
Sat May 12 2012, 06:32PM
yes, changing to a PWM H-Bridge or Full-Bridge
TS00
Sat May 12 2012, 06:37PM
Ok, I get it, you don't like the ZVS. But you have to admit, it is very elegant (up until it explodes). The arcs I got off it were way hotter than anything I've seen with my 555 driven FET.
