  • Guests: 54
Hanzie (31)
badger (52)
h3X (40)
01/10 Hanzie (31)
01/10 badger (52)
01/10 h3X (40)
polyprojectitus
Avalanche
Mon Jul 31 2006, 11:01AM Print
Ok, over the last few weeks I have written down a list of projects. I have all the parts & resources required to build anything here, some projects are listed because I want to build them, others are listed as possible uses for the various parts I have. It's just time/motivation i'm lacking!
So what shall I build first? Feel free to build any of these projects for me also cheesey or add your own ideas if you want...it can turn into a project ideas thread.
- speaking microcontroller
- solar charging LED camping torch
- shortwave regen receiver using FETs
- digital clock using 7 segment displays
- audio amplifier using TDA amp chip
- solar powered clock? lots of solar panels
- DRSSTC - Large *
- SGTC medium (wind the secondary) *
- hall effect thing - scanner, or levitator
- Laser oscilloscope
- mountain bike mounted video camera
- long distance wifi experiments/build antennas
- wireless power transmitter
- PHP content management system modification *
- wind turbine
- learn OpenGL properly
- 1KW petrol generator
- large mains inverter
* = started, but lots to do
Bear in mind anything I do properly will be put onto my website eventually with full write up and everything wink I'm also hoping by listing all this lot here I'll be more motivated to get on and finish some things instead of just surfing the net, watching films and going to the pub wink
Mon Jul 31 2006, 12:05PM
Hi Avalanche
I tried the mountain bike mounted video camera one day. It was a "ghetto" version where I fixed a camera phone to the chest strap on a backpack, and took off down our local dirt jumping trail.
The video was disappointing but still quite funny, all you can see is a blur of bike parts and body parts as the phone shakes around, until finally it comes loose, flies through the air and hits the ground. Then on the soundtrack you can hear me swearing, slamming my brakes on and turning back to get it.
I'd post it but I only have it in 3gp format and can't remember how to convert it. frown
Marko
Mon Jul 31 2006, 12:52PM
Omg avalanche, you owned even my desire for simultaeous projects...
Altough I'm spending more time in sea or sleeping than doing projects at this time ill
It's simply too hot for anything.
Can we see the video Steve? *hassle*
Tesladownunder
Mon Jul 31 2006, 07:20PM
Polyprojectitis? Heres my list
Can Crusher Physics upgrade supply, voltmeter
Can crushing publication further data collection and complete
Laser galvos set up amps and freq generators for display. *urgent
Ball lightning - Double Cylindrical tube. Inert gas, sand, Al dust
Vortex generator signs for display, Coloured powder. Flammable trials, confetti
ZVS running lev coil for efficiency.
Arc in magfield of big electromagnet
Coinshrink other coins, uncovered. Make blast shield.
Ferrofluid display with electomagnet sequence and vertical lifting
Tesla for Physics Dept small ?SISG
New Lifter for Gravity Discovery Center
Super lifter 2 big cells, 80kV
Aim for lifter height record
Lifter boat
Vacuum setup connect (get parts) and run for prelim sparks
Maglev Large and stable. Consider commercial applic.
SSTC for (******* secret)
Marinov motor in display case
Flash high speed photography with Xenon Flash and PFN.
Intensity of capbank flash with CD. Focus with concave mirror for ? burns
Schlieren setup with new mirror.
Test 60kv supply (Big)
Make up 3 phase inverter supply on trolley with filters, cutouts. Also with motor.
Superconducting block to obtain
Cloud chamber (isopropyl ?peltier)
Zamboni battery check foil
Physics TC manual
Blumlein voltage doubler.
Get speaker for better cornflour display.
CW double size
Big caps photo of crushing with flash
TC as HV earth cap
Power of one battery
TC supply
TC cap in secondary
ring plasma
Capacitative spotwelder
Micro TC (********** secret)
Electrolytics for a TC with diodes
BEAM projects
Colorising diet pepsi pad, 9v / Burning Ti
N laser using N2
small TEA
tubular electrodes
flyback supply
Laser 3W YAG
new lamp
macro pics?
refresh water
Laser CO2
manuals buy
supply
Dye laser
SGTC Polypancake
18inch with SRSG
18inch with DC
Big toroid
HV Cap in earth line
planar antenna
Interrupted DC SGTC
VTTC using 30kW tube
18inch
Interruptor
SSTC Royer interrupted
DRSSTC
18inch
Marx 200kv
Electron gun
x-ray tube to make
Argon big Jacobs ladder
Railgun - plasma armature
PIC maglev
IR
keyboard
servo
Model spherical wheels x 1 or 4
Even when you have it all planned, something new comes along. Tomorrow I am picking up two big commercial printing lasers for free. Apart from that most of my spare time for the next 3 weeks will be taken up with tidying up displays for the upcoming Uni physics expo.
Peter
Mon Jul 31 2006, 07:33PM
I have more than I can think of... The top 20 are:
small(er) vttc
get my ftp server working again
get twinview working again
Nd:YAG cnc obliterator
self contained ssy-1 power supply
sell off junk laying arround
sstc
drsstc
make decent case for 811a vttc
make case for sgtc
induction heating
1kw offline zvs
audiomod flyback driver
tube amp
learn html
learn php
lean java
learn c++
make a webserver
make a website
Avalanche
Mon Jul 31 2006, 08:11PM
woh, good to see i'm not the only one who has more ideas than time amazed
wrote ...
haha, that reminds me of when I was going down some hill at abouit 30. I used to fix my phone to the handlebars, anyway it fell off, and I ended up doing a rolling endo for about 20 yards as the phone bounced down the road behind me. When I eventually stopped and found the phone, it had totally popped apart, took a while to gather everything together including the sim, but it worked again.
I was thinking of using an old webcam, and a laptop in my bag. Just need to fabricate some kind of bracket.
Oh, and add Linux to the list. Finally settled for Kubuntu...
Marko
Mon Jul 31 2006, 08:19PM
I think TDU definitely needs a SSTC (maybe a DR after).
Also looking forward big VTTC and CO2 laser 1140483883 10 FT1630 Wink
I didn't even understand the meaning of some titles
''Lifter boat''
''TC as HV earth cap''
''Power of one battery'' - joule theif??
''TC cap in secondary''
''macro pics?''
''refresh water''
''planar antenna''
But I can conclude your polyprojectitis illnes is dire TDU... ;)
Plasmaniac
Mon Jul 31 2006, 08:25PM
Plasmaniac Registered Member #206 Joined: Sat Feb 18 2006, 03:17PM
I cant "beat" TDU, but here my current projects:
-little DRSSTC
-little ISSTC
-big coilgun
-big induction launcher
-plasma "afterburner" for my 2.2kW torch
-led keychain thingie clock
-RC hovercraft
-plasmarailgun
-handheld thompsoncg
-omgextremelysecretproject
And those I'm planning:
-2d scanner for my laser
-LED spinner thingie clock
-TEA2
-reading GB cam
-midi SSTC
-SSY1 (getting the head from a friend)
-induction heater
nothing very special... but still way too many tongue
Hazmatt_(The Underdog)
Mon Jul 31 2006, 10:26PM
As far as building a camping light with solar, don't be surprised if it doesn't do anything desirable. My brother found that at one of the SCA events a group had dozens of these to light their camsite and it didn't work. So heads up there.
TDA amplifiers, well.....don't be surprised by that one either. They just aren't what you think they are. I was attempting to do a 6.1 system with the TDA 1554 stereo chip, and it suked. The chip has great options, but you really have to stick to the spec or else you loose a tremendous amount of power. If you plan to use it at all, use it with 4R speakers. At 8R things work fine until you reach its upper power threshold where it goes from 1%THD to 10% THD and its just AWFUL. My plans were working for a while, but when things got really interesting at higher volumes the quality was too poor and I gave up on the project. A DIY theater surround will cost you ~$300, and to go out and buy a 600W surround with DSP, selector, tuner, and the works costs you $200. So heads up there too.
I still have the heatsink and bracketing the chips are mounted on. A surround system is a bit ambitious, and Yamaha does a much better job then me.
Madgyver
Tue Aug 01 2006, 12:40AM
-Diploma/Master in Mechatronics (its not clear which one we will get now. EU statdartisation is making things difficult)
-watching TV
Yeah, that's too much for me at the moment. What a pity huh?
