  • Guests: 47
My coil winder
Tue May 08 2012, 08:42AM Print
I finally finished my winding machine (very inspired from Terry Fritz's one - Thanks Terry for this nice doc!).
It allows winding of secondaries up to 70 cm long and 40 cm diameter.
It features:
- variable speed from 8 to 150 rpm.
- forward/reverse.
- lap counter
- foot switch
The motor is a 50:1 12V, it starts at 1V, giving a wide range of speeds.
I used two plywood disks covered with hard rubber to hold and drive the coil.
I can finally start building my first two Tesla coils: 811A VTTC and EVR microBrute DRSSTC smile
(You can see my 811A VTTC's secondary form installed on the machine)
Imag0111
Control Box
Imag0112
Reed switch and magnet for the counter.
Imag0113
Close view of the motor, reed switch, and the right coil holder.
Imag0114
Spool holder (Notice the spring which serves to slow the spool, and thus adjust the tension of the wire).
Imag0115
Sigurthr
Wed May 09 2012, 12:41AM
Wow! Very nice! I need to build something like this!
Chip Fixes
Wed May 09 2012, 01:47AM
That's really impressive, nice work!
Tetris
Wed May 09 2012, 02:57PM
Is that stained wood from like a table or something? Or did you stain it yourself, and polish it yourself? LOL, looks very nice though.
Wed May 09 2012, 03:47PM
Thanks all, glad you like it :)
@HighVoltageChick: it is solid oak I bought from this store
You can see how it looks with the spool holder.
0n the winding machine, I applied three coats of polyurethane cherry gloss varnish, sanding lightly after the first coat.
Thu May 24 2012, 02:16AM
Winding my first secondary
This is a tiny secondary for my 811A VTTC. Winding is 15.5cm long with 480 turns of 0.3mm wire (~AWG 28).
Preparing:
Imag0117
First turns:
Imag0118 Imag0119
Close view thru the magnifying glass:
Imag0120
Almost done:
Imag0121
Coating with epoxy. I used Envirotex Lite coumpound with Herr Zapp's method.
(Thanks Herr Zapp for the great tutorial).
Imag0122
Let cure for 8 hours with the winder running at low speed (~5rpm)
(After 8-10 hours you can stop the motor, but wait 72h, hard cure time, before touching the coil)
Imag0123
Done - result is not perfect, but very close to, not bad for a first try smile
The main problem I had was some dust floating in the air.
Imag0212
It's amazing how easy it is to wind secondaries using such a machine. A convenient winding speed for me was around 40 rpm.
Here are two tips I found really essential:
1) Have an adjustable "brake" on the spool holder, allowing a constant and suitable wire tension.
2) While winding, move the spool holder to keep an angle of 90 degrees less 5 to 10 degrees between the coil form and the wire.
Using these two tips you don't even need to guide the wire on the coilform, the winding is tight and there's no space between turns.
Twotip10
RateReducer
Thu May 24 2012, 11:40AM
RateReducer Registered Member #4603 Joined: Wed Apr 25 2012, 07:33PM
Nice construction!
I like the idea with the adjustable break! smile
Thats how i wind my secondarys: Link2
greetings
ZakWolf
Thu May 24 2012, 10:23PM
how did you add the labels on the counter box?
Fri May 25 2012, 03:11AM
@RateReducer: it's cool to have access to a lathe smile
ZakWolf wrote ...
I used transfer lettering for PCB's.
Then I applied a coat of varnish spray for PCB insulation and protection.
