  • Guests: 34
01/18 Noelle (43)
01/18 King_of_Junk (36)
01/18 Ixz (35)
Just a question on SGTC spark length
Sat May 05 2012, 11:49AM Print
Hi,
I have never built an SGTC so I have no idea about this...
If I was going to build a SRSGTC with 10kVA of input power (so the kW might be in the 5-7 range but I don't really know), at 100 bps (synchronous with 50 Hz), what spark length can I expect when everything is tuned properly?
Thanks
Kizmo
Sat May 05 2012, 01:57PM
Here is my DC spark gapper at around 6-7kW. Longest sparks it made were about 3 meters so far. Still needs more testing and tuning but my rectifier failed.
1336226237 599 FT137968 Sparks
Sat May 05 2012, 09:54PM
Some years ago John Freau came up with an approximation;
Spark length = 1.7 x sqrt(Watts) ... inches.
e.g. for Kizmo 1.7 x sqrt(6500) = 137 inches =3.48 m
Sun May 06 2012, 08:22AM
Thanks for the replies smile
Sulaiman, from my experience the square root relation between power and spark length is not 100% correct, a 4x increase in power seems to lenghten the sparks more than 2 times, at least on continuous oscillation coils.
Anyway, I calculated the tank capacitor to ~0.15uF with charging voltage of 30kV, which is really big I think there's no way for me to get such capacitor, so this project will most likely not happen.
