  • Guests: 48
rsgtc motor and caps
Ben Solon
Thu May 03 2012, 12:01AM Print
so. for a very slow physics project i am doing with my ap teacher and a few other students, we are working on a rsgtc using mots and an asynchronous spark gap. because i have only built static gaps and ss coils before, i would like to have a bit of input from those who have built these before.
first off: i have a 170vdc 4.6A motor(and its the best thing i can easily get my hands on) which spins at 5500rpm. WAYYY too fast for a spark gap. but using full wave rectification we get 100rpm and half wave gets 125(no filter cap, see below). this was measured by sticking a small piece of tape on the axle, then touching it while recording with audacity. but anyways, is there any way to easily modify the speed without a variac? i thought maybe triac's like in a dimmer switch, but it may not work so well with an inductive load.
second: what is a decent break rate for a dc charging tesla coil with a small capacitor. the tank cap is a large bank of al foil and overhead transparencies. easily 5nF per cap, and we can make quite a few smile
third: what is a decent filter cap for my motor? i think the reason its going so slowly is the lack of a constant power source
(nope, actualy i know that that is the reason tongue)
if it helps, we are using two series mot's perhaps with voltage doubling or tripling. it depends on experimentation with the system after first light. the coil is maybe 100-200khz including torroid.
also, any other tips would help too, this is my largest coil yet to date.
