  • Guests: 97
RoV IW3IPD (63)
01/12 RoV IW3IPD (63)
Kelvin Generator powering an Electrostatic Motor
Sun Apr 29 2012, 03:38AM Print
Everyting is in the title ... ;)
Some explanations about Kelvin Generator's principle :
http://en.wikipedia.org/wiki/Kelvin_water_dropper
Patric
Sun Apr 29 2012, 10:11AM
Patric Registered Member #2899 Joined: Wed Jun 02 2010, 06:31PM
Beautiful, astonishing!
IntraWinding
Sun Apr 29 2012, 11:56AM
Dripping water to rotary motion converter! shades
Got any aesthetically pleasing electrostatic motor designs?
Antonio
Sun Apr 29 2012, 01:31PM
Well done. Simple construction, correct insulation, and works. There is a better version of this generator where the output is not taken from the two cans below, but from another set of two cans, that receive water from two additional dripping sources, passing through two extra inductor rings connected to the inductor rings of the main machine. In this way the charges in the cans of the first machine are not used, and the device reaches much higher voltages.
testtest
Sun Apr 29 2012, 08:51PM
testtest Registered Member #3271 Joined: Mon Oct 04 2010, 02:29AM
very nice demo! congrats.
You might get more efficiency just using a paddle wheel on the falling water thought..... smile
Tue May 01 2012, 12:05AM
Thanks all, glad you like it :)
This is a quick and dirty build (but efficient, the most important thing is insulation).
I got up to 5mm sparks. One improvement could be having no sharp edges.
@IntraWinding: most of the electrostatic motors designs I could find were quick and dirty.
But I think my design can be made nice looking. I'm planning to do it... I would just replace
the plastic socle with a nice thick plexiglass plate with polished edges, and use some nice
vintage style brass supports for the electrodes. Most inportant thing for this motor is to have less friction as possible. I used a sewing needle as an axis, and the glass cap of a breakable medicine glass bulb.
@Antonio: This sounds interesting, thanks. I'll try this setup if I build another unit.
@richnormand: That's right ^^ Most of the energy is wasted as heat when the water drops land in the buckets.
