  • Guests: 35
Tesla coil secondaries are tough!
Kizmo
Sat Apr 28 2012, 08:14AM Print
Its just unbelievable what kind of abuse these things can handle. Couple days ago i put together my very first SGTC. About 5 years ago i managed to burn it pretty well with way too high coupling and bad tuning which resulted shorted turns and carbon tracks under the windings. Back then i just unwound the lower part of the coil, ground all carbonized stuff away and rewound. When repair was done it was left sitting in corner for almost 5 years.
What i didnt know was the fact that those under winding carbonized spots went all the way up to middle section although rest of the coil looked ok.
When i powered this secondary couple days ago i had almost instantly some turn-to-turn arcing and after that massive lump of red hot shorted turns.
Needless to say i was sort of frustrated to see that happening again. I simply unwound all charred turns, then scraped visible carbonized plastic away, twisted wire ends together and pressed this twisted knot against the former to make it somewhat flush with the surface. I didnt even scrape wire ends to bare copper before twisting. I had to do this repair twice on two different spots.
It worked like new.
1335600823 599 FT0 Secondary Repairs
1335600863 599 FT0 Dsc 0720
Sigurthr
Sat Apr 28 2012, 08:42AM
Wow nice! I assume the coil is laquered because if not it would have been a nightmare to remove a section without the entire thing unwinding. What gauge is that btw?
I'm going to wind my first DIY secondary some time next week when my wire arrives.. both excited to start it and not looking forward to it at the same time, haha. Hand winding 20" on a 4" form w/ 30ga is going to be an experience. I bought my current SGTC's (tiny) secondary already wound, haha.
Kizmo
Sat Apr 28 2012, 08:45AM
Yep it is coated with polyurethane. But these repairs are fully uncoated :p
Wire was 0.50mm diameter which is about AWG24
Sat Apr 28 2012, 09:03AM
Depends on your point of view, I have seen several little secondaries deformed from heat, after longer runs in small low power sstcs/vttcs :p I face the problem of overheating secondaries all the time, in continuous-oscillation coils (VTTC, SSTC)...
Dr. Drone
Sat Apr 28 2012, 03:31PM
shades
Tetris
Sat Apr 28 2012, 09:33PM
Urgh, i remember when my secondary was wound. first time, wire broke half way through. second time, i saw it wasn't good enough. third time, after a few runs, I noticed that along with gaps and crosses despite the poly, was a break in the wire. Fourth time... ??? I'll know in the summer.
Kizmo
Sun Apr 29 2012, 10:04PM
Still no deadly flashovers. 4x secondary lenght...
RateReducer
Mon Apr 30 2012, 11:45AM
RateReducer Registered Member #4603 Joined: Wed Apr 25 2012, 07:33PM
Awesome coil! amazed
How much input power?
Kizmo
Mon Apr 30 2012, 11:52AM
I didnt have current meter but judging from variac vibration the current draw was less than 10amps/phase
Maybe 5-6kVA?
