  • Guests: 40
10/09 sbs_2010 (34)
10/09 SoundDoc (50)
10/10 Ryan Parle (44)
Celem capacitor repair (drop damage)
Kizmo
Fri Apr 27 2012, 09:50PM Print
So i got myself a nice Celem CPRI300 (1µF 650A 300kVAR) which was little bit damaged:
1335562588 599 FT0 Large Chunk Missing
1335562687 599 FT0 Still Fine
Step 1: Removing all loose plastic bits, opening couple cracks and roughing shiny surfaces for better adhesion
1335562848 599 FT0 Grinding
Step 2: Filler i used here is "Chemical metal". Its 2-component really strong and oil/water resistant stuff. It has nothing to do with metals so its not conductive:
1335562930 599 FT0 Filler
Step 3: Several rounds of building missing chunks of plastic and sanding
1335562967 599 FT0 2nd Filler Pass
Step 4: Milling machine was easiest way of cutting the shoulder part back to original dimensions
1335563058 599 FT0 Milling
Sanding done:
1335563032 599 FT0 After Sanding
Step 5: As usual, this celem cap had horrible surface finish o both terminals. Little fly cutting should help.
1335563154 599 FT0 Resurface
Step 6: Finished repair after quick coat of black automotive paint. Looks like new.
1335563314 599 FT0 Finished Product
Will it work? I dont know. Measures good, survived high voltage test (950VDC) fine.
I think we need to find out with real induction heater application...
Sat Apr 28 2012, 06:02AM
Good job!
Looks better than new and I will certainly look into persuading my father to get a fly cutter for his mill, its a rather small mill so is it even possible?
Kizmo
Sat Apr 28 2012, 07:31AM
And yes, you can flycut even with small mill. Just make sure to use sharp tool that keeps the cutting forces small and it shouldnt be problem.
