  • Guests: 46
Pentode into tetrode
Fri Apr 20 2012, 06:18PM Print
Hi,
I was playing with my VTTC which uses a Russian GU-81 transmitting pentode. Originally I had it connected as a pentode, with the screen supplied from auxiliary supply and the suppressor to the cathode. I wondered what might happen when I connect the screen and the suppressor grids together. The screen+suppressor current did increase a bit, but not much (~130mA vs 110mA previously), the plate input increased and the sparks are longer.
I wonder if there are any problems with doing this? Or should I go another way about increasing the power? Why do they use pentodes in power transmitters?
Any ideas welcome smile
teravolt
Fri Apr 20 2012, 06:26PM
do you think the tube is far out of its safe operating erea.
Fri Apr 20 2012, 06:30PM
I think the dissipations are within limits, AFAIK the plate never got red, at least before the modification, but I too haven't seen it getting red now. The cathode peak current however might be exceeding 6 amps, but I think a directly heated cathode doesn't mind much.
Sat Apr 21 2012, 05:57AM
They used pentodes because the beam tetrode wasn't invented at that point. tongue
The suppressor grid makes the pentode more linear than a plain tetrode, which is important in a RF amplifier to avoid interference to other channels. This doesn't matter in a VTTC, so you can do whatever you like with it.
Myke
Sat Apr 21 2012, 06:40AM
If you did connect the two grids together, wouldn't you have to worry about melting your suppressor grid
since they aren't really built to dissipate any power unless I'm misinformed?
Sat Apr 21 2012, 10:09AM
Thanks for the replies smile
Myke, the suppresor grid in this tube is pretty robust. The g2+g3 current increase was just some 20 mA, so I suppose this is the current which flows to the suppresor grid. This is a 12 watt dissipation, while the screen is designed to dissipate up to 120 watts, so I believe this is not a problem.
