  • Guests: 48
Proud Mary (62)
omegalabs (39)
Plasma Lover (32)
09/16 Michael Witt (36)
09/16 AleSeg (15)
09/17 Jyardana (41)
Flowing CO2 Laser Flow Rates
Pinkamena
Thu Apr 19 2012, 10:27AM
Pinkamena Registered Member #4237 Joined: Tue Nov 29 2011, 02:49PM
I find homemade lasers very interesting (but way out of my comfort area when it comes to actually building one)! Say, have you got an estimate of how powerful the laser will be?
sngecko
Thu Apr 19 2012, 11:58AM
sngecko Registered Member #3447 Joined: Fri Nov 26 2010, 11:10PM
Thanks guys.
I'm actually planning to have two 15mm ID tubes fabricated with 32mm jackets. The overall length of each leg is 1200mm with three-rod tube supports halfway. They will be blown into one piece with coolant hose barbs, then I'll have a company make glass-to-metal seals on the ends to 2-3/4 Conflat flanges. The optical cells will be built into the Conflat specification. In this arrangement, and with my power supply and regulator, I'll have one anode and two cathodes.
The slow-flow LEOT Class I laser equation gives an output on the order of 140W. We'll see, but I'm expecting this to take some time. Especially because my current regulator has been acting up with some high-frequency oscillations somewhere, probably in the triode. (See High Voltage forum, under Oscillations Redux).
