  • Guests: 48
01/18 Noelle (43)
01/18 King_of_Junk (36)
01/18 Ixz (35)
Quick advise Tesla with 807?
Patric
Wed Apr 11 2012, 03:58PM Print
Patric Registered Member #2899 Joined: Wed Jun 02 2010, 06:31PM
I plan to make a VTTC with a 807. Long ago this tube was used to make my first 80m-transmitter! Those were the days...
Thu Apr 12 2012, 11:10AM
Just a quick warning, don't use a MOT to power it. I would go for a voltage multiplier from mains, and you can put a MOSFET interrupter in the cathode.
Patric
Thu Apr 12 2012, 11:57AM
Thanks! I have a transformer who gives 750VAC. Is it possible to use the 807 with that voltage, without rectifying it?
Thu Apr 12 2012, 12:06PM
I think it is.
Patric
Fri Apr 13 2012, 10:04AM
Thanks! smile
Patric
Mon Apr 16 2012, 08:30PM
I can choose my resonant frequency between 1 and 2 MHZ. What is best? (most impressive smile )
Mon Apr 16 2012, 09:42PM
I would definitely go for 1 MHz, you should get longer sparks.
Patric
Mon Apr 23 2012, 02:37PM
So, this is it. I hope to get sparks from about 1/2 inch. Can something be improved? I plan to get it at work at the end of the week, and I'll be back! smile
1335191585 2899 FT136903 Tesla807
Patric
Tue Apr 24 2012, 07:40PM
It works already! But I only have a little spark of... one millimetre (4/1000 of an inch) sad
Tue Apr 24 2012, 08:14PM
If you can, tap the plate transformer somewhere in the middle for the screen supply. Then decrease screen resistance to something like 10k and put a .01uF ceramic cap from screen grid to cathode. Increase control grid resistance to 47k and use something like 470pf across the resistor.
Increase the resonant cap to maybe 2200-4700pf, re-calculate primary turns, use tuning taps. You may need to tap in less than 1 turn steps. When designing the new primary, aim for a pretty high coupling, but not too much.
