  • Guests: 37
williamn (48)
ReddyK (57)
Birdman (31)
12/14 M.A.D. (32)
12/15 marko666 (58)
12/16 Will T (16)
What wrong with my new ZVS?
Harry
Thu Apr 12 2012, 03:28PM
Harry Registered Member #4081 Joined: Wed Aug 31 2011, 06:40PM
I'd say buy some IRFP260's (or 250's, I see no difference between the two in real life)
Or buy another ZVS driver :P
Gabriel35
Thu Apr 12 2012, 07:28PM
Gabriel35 Registered Member #2310 Joined: Wed Aug 19 2009, 08:04PM
No difference? And what aboun the lower RDS(ON) of the 260N and higher current capability?
Harry
Thu Apr 12 2012, 07:32PM
I'm not saying the 260 isn't better, but in this circuit I saw no noticable difference when I swapped the 250's with 260's.
However when I built the Mazzili induction heater replacing 250's with 260's really made a difference as I was pulling around 30 amps.
Platinum
Thu Apr 12 2012, 10:23PM
The 260's can handle much higher current, and that means fatter arcs.
Harry
Fri Apr 13 2012, 08:55AM
But ZVS flyback driver generally only pull around 10 amps, which both 'FETs can ahndle just fine.
Platinum
Sat Apr 14 2012, 11:50PM
Harry wrote ...
10 at what voltage?, most people run them at 36v.
Harry
Sun Apr 15 2012, 08:24AM
Yes it is around that voltage, but I use a transformer so there may be some voltage sag. They still don't heat up though.
