  • Guests: 50
Sanchez (36)
Knarvel (13)
10/17 Madgyver (40)
10/17 mike0t4ever (43)
10/17 Ken M. (40)
What wrong with my new ZVS?
Harry
Mon Apr 09 2012, 09:33PM
Harry Registered Member #4081 Joined: Wed Aug 31 2011, 06:40PM
Try putting a diode from the emitter to the collector, similar to a MOSFET. If that fails, just use IRFP250/60's.
Platinum
Mon Apr 09 2012, 09:51PM
It has diodes like the original ZVS, but do you mean add more UF to both IGBT's
This IGBT has a diode from G > E.
Harry
Mon Apr 09 2012, 10:01PM
Nope I mean add an extra diode from the emitter to the collector of the IGBT. Like the way a 'FET has a diode from source to drain:
1334008900 4081 FT136767 Mosfet1
Platinum
Tue Apr 10 2012, 12:19AM
I tried adding 460'n I got it working, but then it just completely died.
I'm going to rebuilt it agin, from scratch, check if every component is well, but they way I built it was terrible I'm trying to think of a better way.
Gabriel35
Tue Apr 10 2012, 02:30AM
Gabriel35 Registered Member #2310 Joined: Wed Aug 19 2009, 08:04PM
Don't know exactly why, but this circuit seems not to work well with IGBTs, and one of the causes is that IGBT's speed isn't good for like 100kHz or more.
So I think that that's the main reason it's not working.
I would best recommend IRFP260N!
Platinum
Tue Apr 10 2012, 08:51PM
*facepalm* zener was mangled, using a separate supply for gates
My SSTC is around 170w now, never had a TC with this much current.
The Fres is 448Khz, I'm using a 0.1uF (100nf?) cap, as this is whats called for, and 2t primary.
But adding toploads doesn't do anything.
ZVS dead again, not MOSFETs? I've given up.
Harry
Wed Apr 11 2012, 07:56AM
Try rebuilding the ZVS, so everything is clearly laid out.
If that fails, I think you might have to buy some new parts :(
Platinum
Wed Apr 11 2012, 12:00PM
Last time it was a zener, now it's probably a resistor.
I can't re-build it, my soldering iron needs a new tip :(
Harry
Wed Apr 11 2012, 12:25PM
Have you checked all the resistors with a multimeter?
Check everything, IGBT's, zeners (again) other diodes, power supply and that any windings haven't shorted out.
I guess you'll just have to wait for a new tip though.
Platinum
Wed Apr 11 2012, 03:19PM
Just found an old soldering iron tip, not good, but usable, checked everything, diodes, IGBT's, resistors, all OK. No shorts, there seems to be nothing wrong, but is :(
