  • Guests: 73
RoV IW3IPD (63)
01/12 RoV IW3IPD (63)
Use water glass as HV insulator?
Wed Mar 28 2012, 06:46AM Print
Hi all.
Just had an idea, could water glass (aka sodium silicate) be used to insulate say a cardboard secondary former to use it for high voltage applications?
This would be particularly useful as it has a surface consistency similar to glass, yet chemically identical.
It does have some sodium ions present but this isn't likely to be as big a problem as usual.
Tried it with a piece of copper and EL phosphor, which glows as bright as usual under UV once the water glass has cured with mild heating < 70C for a few hours.
Comments?
(plus its a heck of a lot cheaper than Epoxy and substantially less toxic)
Wed Mar 28 2012, 07:35AM
we used sodium glass in chemistry class for all the least sensitve reactions, is that the same stuff?
Wed Mar 28 2012, 11:38AM
"When completely dehydrated, sodium and potassium silicates exhibit good dielectric properties."
Extracted from: Link2
Ben Solon
Wed Mar 28 2012, 05:35PM
As stated, when dry, it should work well. Just watch out for surface tracking. While glass doesn't conduct, it allows surface tracking easier than say, a plastic or film dielectric.
radiotech
Wed Mar 28 2012, 07:25PM
I have some glass pH probes Do they conduct?
Bored Chemist
Wed Mar 28 2012, 08:00PM
radiotech wrote ...
Yes, but probably very badly.
I don't know about water glass, but fire cement is a fairly good insulator and the binder in it is sodium silicate.
However, be warned, when it gets hot it conducts quite well (like ordinary glass), which could lead to thermal runaway.
Pinky's Brain
Wed Mar 28 2012, 08:18PM
Pinky&#039;s Brain Registered Member #2901 Joined: Thu Jun 03 2010, 01:25PM
Does a sodium silicate solution naturally produce a continuous polycrystalline film during dehydration? If it creates flakes or scales it won't be much use obviously.
Thu Mar 29 2012, 09:04AM
Pinky's Brain wrote ...
The exact properties of a sodium silicate glass depend on its SiO2/Na2O ratio, but all are polymeric and water-soluble.
Fri Mar 30 2012, 06:42AM
hm..
So I'd need to insulate it with Epoxy as well.
Still, an interesting experiment to try as putting it between two sheets of real glass then insulating the edges could work well for all sorts of applications.
Fri Mar 30 2012, 07:57AM
You'll like this one, André. Tells you how to make doped silicate layers using very simple methods.
Montaser M et al: ZnO doped sodium silicate preionize N2 Laser Chinese Physics Letters Vol 6, No. 11, (1989) 491
Which you can download here: Link2
