  • Guests: 26
Pyromaniac (34)
Wavetuner (76)
jeffomatic (75)
SparkLabs (36)
10/09 sbs_2010 (34)
10/09 SoundDoc (50)
10/10 Ryan Parle (44)
SSTC-2
Sat Mar 24 2012, 09:29AM Print
Hi,
im planning to be build the SSTC-2,
where i live we run on 240v, i dont fancy halfing my voltage in, so is there any IGBTs or MOSFETS
i can use for it instead of the IRFP260s?
mabye IRFP450?
thanks,
Tom Williamson
Sat Mar 24 2012, 06:34PM
Hi,
the equivalent part for double voltage is the IRFP360 (400 volt), but I would rather use the IRFP460 (500 volt) for some voltage headroom.
ah, ok, thanks!
Sat Mar 24 2012, 07:42PM
What you want to do, is what I did some years back with Wards SSTC2, Link2
Sat Mar 24 2012, 09:51PM
ah, ok thanks, how much did it cost you to make it anyway?
Ben Solon
Sat Mar 24 2012, 09:59PM
wait. you have no need for doubling, and your mains voltage is what us in the USA would get using a doubler. so just inverse the operation. use a full wave bridge rectifier to charge two series capacitors. then the voltage across each cap is half of the total voltage. if you use a half bridge, you can use the tap between the caps for the "0" voltage. then use the top and bottom rails as your + and - rails. or plan accordingly if using a full bridge.
Sat Mar 24 2012, 10:13PM
hmm, i just noticed, how come Mad's SSTC2 came out with less spark in it then Steves, is there any way i can imporve it more?
-Tom
Ben Solon
Sun Mar 25 2012, 01:27AM
what frequency are you running it at? i have found that in situations some igbts can greatly improve performance by eliminating the on resistance. this also limits heating issues. in a coil i recently built, i used some hgtg30n60b3d igbts up to 1.2MHz with no problems. when the class e coil was completely untuned(hard switching) the devices only heated slightly. i could run the coil for hours. then with a mosfet, i could only run about 5 mins on low duty interrupt. they are rated for 600v, so i recommend running higher bridge voltages. just make sure you have over voltage protection.
Mon Mar 26 2012, 07:01PM
Tom Williamson wrote ...
-Tom
I just realized that it was Wards SSTC5 that I built, as a full bridge version. It was relative cheap to build, maximum 50$ or so, most materials are scavenged
Mon Mar 26 2012, 08:03PM
Ah, Thanks ^^
