  • Guests: 43
eeprom under 100x magnification
Ben Solon
Sun Mar 18 2012, 10:06PM Print
Today I had a friend in biology science visit with his microscope. I happened to have a uv eeprom laying around, and we took a look. It is simply amazing how small these things are. Under 100x magnification you still can’t individually point out a single transistor or other semiconductor. The video we came up with is below.
We also managed to get a reasonable shot of the materials in a 1n4148 diode. After quite a few wasted ones of course. I think my friend and I may do more of this in the future, coming up with images of the insides of semiconductors. I will put what I have up on my website: electronics324.comoj.com
Also, anyone who wants to see some pretty cool videos of protists and other bio stuff, his channel is lukem1221 on youtube :)
Turkey9
Sun Mar 18 2012, 11:03PM
No video!!! Oh no!!! frown
Ben Solon
Mon Mar 19 2012, 12:13AM
oops. first time linking to youtube fail! fixed now...
Turkey9
Mon Mar 19 2012, 12:34AM
Wow, that is really cool. I liked seeing the grid area that I can only imagine is where the info is actually stored. Also, how did you separate the die from the package?
Ben Solon
Mon Mar 19 2012, 01:31AM
it was uv erasable eeprom, so the die was sitting in a hollow chamber with a glass window for exposure. i just took a chisel to cut out the middle. and actually, we got to see it at 400x and see individual "cells", but it was extremely difficult to line up the light source on the microscope. so no images of that :P but because it is 256kb it makes sense that there are a quarter of a million memory latches!
Jrz126
Wed Mar 21 2012, 10:10AM
This was taken with a cheapo digital camera. No zoom needed. The larger squares are the IGBTs, gate terminal in the center. The smaller squares above it are the recovery/freewheel diodes.
Wed Mar 21 2012, 12:49PM
Hi Ben,
standard biological microscope objectives are designed to accommodate the refraction caused by the cover glass on a microscope slide, and cannot be brought to a sharp focus without one, as we see in your pictures.
For higher magnifications, there are designated water and oil immersion objectives, which accommodate the refractive index of these fluids when they are used as a medium between the submerged specimen and the front face of the objective lens.
Ideally, one should use a metallurgical objective for your kind of study, since these are designed to focus directly on the specimen through the air.
You will get better results with a standard biological objective if you bond a microscope cover slip directly to your chip using Canada Balsam, (or a synthetic equivalent) which has the same refractive index as a standard cover slide glass.
