  • Guests: 61
Would a laptop survive an EMP?
Inducktion
Sun Mar 18 2012, 04:44PM Print
Just an idle thought, since I've seen people on here zapping laptops with Tesla Coils, and reportedly, they still worked afterwards...
Laptops have a lot of RFI shielding, so it would make a faraday cage around it yes?
Sun Mar 18 2012, 05:37PM
i would personaly think that it depends on the size and range of the EMP, the feather away it is, the less current and voltage it induces in the wires after all...
a very strong one, theoreticly could totaly destroy the faraday cage, after all, from what i know a EMP works like a huge, giant pulse transformer as far as im concerned
and a large enough pulse of EM could induce a current large enough to melt the metal cage
--Thomas Williamson
Tetris
Sun Mar 18 2012, 09:42PM
Goodchild has a video on his youtube channel of this.
Goodchild
Mon Mar 19 2012, 01:45AM
There is a big difference between EMP and an E Field. The laptop in my video was only hit with an E field or more specifically I passed current through it but the E field around it was rather weak.
For an EMP you need a supper strong supper short blast of Electromagnetic energy, this would induce currents in all of the little traces in the integrated circuits causing them to heat up and fail. In close proximity to an atomic or thermal nuclear blast this would kill most unshelled integrated circuits (including laptops). an EMP can also be created with a capacitor discharge bank if set up correctly.
In my video the laptop is not really being hit with EMP.
genious 7
Mon Mar 19 2012, 09:44PM
genious 7 Registered Member #2887 Joined: Sat May 29 2010, 11:10PM
Dunno, but if it if connected to its charger, the cable will act as a nice antenna. I know someone has damaged a laptop with a Marx generator because of this.
I can only assume other cables (usb mouse) would also do the same.
Tue Mar 20 2012, 08:12AM
One interesting little titbit I found online.
Its possible to make an "EMP Simulator" using a modified microwave with a high voltage rated vacuum relay in series with the -5KV from the capacitor.
(DANGER WARNING LETHAL VOLTAGE ETC YADAYADA)
Needless to say, it only works with industrial sized (i.e. physically large) microwaves, and it is essential to leave the interlocks etc intact so it won't turn on by accident.
The heater coil is left intact and connected to the existing control circuitry so that it shuts off correctly when the power turns off.
This ensures that the heater is kept hot, so switching the relay briefly will yield a short pulse of microwaves consistent with an EMP or accidental sweep with a high power millimetre wave radar.
You can even set the pulse width from a few ms to seconds, which is handy indeed for chemistry synthesis etc where precise average power needs to be maintained.
With a few more modifications the magnetic component can also be simulated, winding a multilayer coil and coating it with BiSnPb connected to the cavity then placing it directly under the equipment under test would work.
Best to put the coil where the existing rotator and plate went, as the existing hole(s) can then be used.
Needs feedthroughs to keep the microwave energy inside the cavity though..
-A
Forty
Tue Mar 20 2012, 04:49PM
Ah, so that's what I was doing when I was applying sparks to a magnetron at college and blipping out all the speakers in my apartment.
I wonder if it would "simulate" better if I discharged a hv capacitor bank into it via spark gap.
I'm not sure about laptops, but most other compact high tech devices I've taken apart have many layers to them with shielding in between (more to shield one region from the next internally I think, but I suppose it would work for external emp)
While the melting current emp is an interesting idea, I imagine the repulsive force between the current and the emp would rip the shield/device apart before it could melt.
Oo that actually gives me an idea to counter what I just said using metal leaf on a block of wood placed on an induction launcher...
Tue Mar 20 2012, 10:42PM
I think a MWO magnetron (or a radar transmitter) generates an EMP qualitatively very different from a high altitude nuclear detonation.
The former produces E and H fields alternating at GHz frequencies, with an envelope that builds up and then decays over many cycles. The spectrum is dominated by the microwave oscillator frequency; shielding and damage effects would depend on target behavior at that frequency.
The latter is not fundamentally oscillatory. A ball of air absorbs x-rays/gamma rays, resulting in fast electrons which leave the positive ions far behind. Would be radially symmetric if near sea level (like conundrum's avatar image!). At the near-vacuum density hundreds of km up, it's bigger than the scale height of Earth's atmosphere. That makes the charge separation unsymmetric. I bet the effect of the geomagnetic field is not too significant in the first microseconds.
So I bet the E and H waveforms are more like monopulses, perhaps followed by some overshoot in the opposite direction. The spectrum from 100 MHz down to kHz or lower would be (AFAIK) pretty much the Fourier transform of the envelope.
Here's an article about a contemporary risk assessment. Link2
[edit] In response to the thread title question: I think small gadgets like smart phones, maybe even laptops, could be undamaged. Unless plugged into their charger at the time. smile
Land line and wireless comm networks, and the electric power grid, and grid powered computers are what the planners worry about.
Hon1nbo
Thu Mar 22 2012, 11:46AM
I remember QST having an article a year or two back relating to the protection of equipment from an EMP burst, and how to implement it yourself.
I'll see if I can dig it up from the stack, and maybe share a few details.
However, I think a laptop or desktop on its own would not survive even with the metal shielding for reasons mentioned by others and due to the fact that most cables going into and out of a machine would not be able to adequately protect against generating current going into the machine.
-Jimmy
Thu Mar 22 2012, 07:13PM
With North Korea about to launch a satellite, it seems to be a topical issue for discussion.
I was thinking today how to shield a weather balloon with attached wifi and radiation monitoring from EMP.
I expect that a simple double shield where all the components are well isolated would stop most if not all of the energy.
Maybe retract the antenna except when it is being used and use optical comms to send telemetry?
-A
