  • Guests: 68
HV capacitors from Goldmine
kimbomba
Fri Mar 16 2012, 02:36AM Print
kimbomba Registered Member #3854 Joined: Fri Apr 29 2011, 03:45AM
Has anyone tried these capacitors from goldmine?
They were advertised as 35 Kv sometime ago, now they advertise as 4KV. However I have tested them making sparks with a gap of more than 3 cm several times and they perform with no problem (immersed in oil). So i think they really are 35 KV. What would be a good use for them?
Forty
Sat Mar 17 2012, 02:19PM
They look like the capacitors found inside of DC tv flyback transformers (I've never gotten one out undamaged but that's what they look like.)
They could probably be used in any hv circuit. They could make a powerful marx generator due to their (comparatively) high capacitance but it would be tricky to build with all the caps under oil.
A CW multiplier might also work (and the whole thing could be submerged.)
Several of them could be seriesed/paralleled for a tesla coil capacitor.
