  • Guests: 132
Madgyver (40)
mike0t4ever (43)
Ken M. (40)
tesla500 (39)
Fabi (32)
hatto018 (40)
10/17 mike0t4ever (43)
10/17 Ken M. (40)
Using saltwater caps as capacitor for my tesla coil.
Zeeb
Sat Mar 10 2012, 03:42PM Print
Zeeb Registered Member #4398 Joined: Wed Feb 08 2012, 07:04PM
There are 2 things I’m wondering about when using saltwater caps as capacitor. First, I was reading up on some alternatives like using MMC capacitors and I noticed many people making calculations so there transformers capacitance would match that of their capacitor. Do I need to match capacitance of my saltwater caps with my transformer as well? If so, does anyone know where I can find the formula for calculating the capacitance on each saltwater cap and their voltage? I've looked almost everywhere and can't seem to find any formulas for saltwater caps :/
The second thing I’m wondering about is how big can the voltage difference be between the transformer and the capacitor? Is it ok to have a transformer that can produce 4000v and a capacitor that can handle 20k?
Luceš
Sat Mar 10 2012, 07:58PM
Luceš Registered Member #4108 Joined: Sun Sept 25 2011, 11:43PM
There almost is way to calculate capacitance on salt water capacitors, you can though if you know the characteristics of the dielectric, although the calcs will be inaccurate, you won't need to worry about voltage with salt water caps, but with MMC's typically should be rate twice (or more) of your supply voltage
Zeeb
Tue Mar 13 2012, 06:47PM
Thanks for the response. But if I can’t calculate the capacitance on my saltwater caps. How am I supposed to know how many caps I need for my transformer? I’m using a neon sign transformer with 4000v 0,045A 50 hertz. calculated capacitance at 0,0348 uF
Zeeb
Thu Mar 15 2012, 05:56PM
I guess I could use a multimeter for checking the capacitance but it seems like quite a tedious task checking the capacitance, adding another bottle, checking it again.. until desired capacitance is reached:s is their no other solution to get the preferred capacitance when using saltwater cap?
Ash Small
Tue Mar 20 2012, 06:46PM
If I remember correctly, a 2 litre polythene drinks bottle full of saltwater and wrapped in aliminium foil is around 50 nF.
build one, measure it's capacitance using a meter, then work out approximately how many you will need.
Tue Mar 20 2012, 11:14PM
I don't know about plastic soda bottles, but beer bottles are about 1nF each.
Tesla's Colorado Springs Notes has a section on all the different bottles he tried for his capacitors. He measured the capacitance and also the breakdown voltage, by cranking up his experimental coil until the bottles shattered. Maniton mineral water was his favourite, but the data probably isn't too relevant to modern bottles.
