  • Guests: 55
flyback trouble
Legit_bacon
Sun Mar 04 2012, 02:01AM Print
Legit_bacon Registered Member #4034 Joined: Thu Jul 28 2011, 10:41PM
I've been rebuilding my coilgun and have run into some problems with my rewound flyback, I have 5 turns on my primary and around 300 on my secondary driven by a simple 555 driver at 12volts. but Im only getting 80volts out, and I can't diggiee out why, any ideas?
kimbomba
Sun Mar 04 2012, 02:17AM
kimbomba Registered Member #3854 Joined: Fri Apr 29 2011, 03:45AM
Did you leave an airgap in the core?
Legit_bacon
Sun Mar 04 2012, 04:48AM
i've added a airgap now, no change
ZakWolf
Sun Mar 04 2012, 05:55AM
Im not sure of your space constraints but i would recommend uzzors2k "50W Capacitor Charger" Link2 I made it and im fitting into a mini coil gun.
Mine uses 1 450 1800uf cap that charges in 5 secs.
Other then that, the 555 timer driver is pretty weak, i have tried it in the past with poor results
Alex M
Sun Mar 04 2012, 08:58AM
ZakWolf wrote ...
I second this. I built a ZVS based charger minus the regulator part and it charges very quickly on just 12v input.
Legit_bacon
Sun Mar 04 2012, 09:36AM
don't have the resources or the time at the moment. but I'm not charging a large cap only 250v 3000uf so 100 j~ and small size constrains this barely fits and It's tiny. any idea why I'm only getting 80v? I Get 5cm sparks of a normal flyback with it so the circuit works fine.
Newton Brawn
Mon Mar 05 2012, 12:27AM
Newton Brawn Registered Member #3343 Joined: Thu Oct 21 2010, 04:06PM
Hi Mac !
It is difficult to advise just based in your above description.
Why you do not show the circuit schematic and some pictures ?
Regards
Legit_bacon
Mon Mar 05 2012, 02:33AM
Link2 is my circuit, first on the page. ill post some pictures soon.
Forty
Mon Mar 05 2012, 06:20AM
Have you considered trying uzzor's boost converter?
similar parts, intended to charge capacitors, and smaller size.
and if you're set on the flyback then whats your transformer look like? is one coil inside the other? are the windings insulated well from each other and the core? do you have thick primary turns? If you only need 250v out, and your secondary has 300 turns, then you could use as many as 14 primary turns. Have you adjusted the frequency so that you get the maximum output? Was the open circuit voltage 80 volts or is that all it was charging your caps up to?
Legit_bacon
Mon Mar 05 2012, 08:26AM
Okay, so i'd rather not go building a new circuit because this is just a side project i thought is whip up over a weekend with a friend using stuff i had lying around (amazing what i found on the mass that is my desk). Right so i origonaly tried 105turns secondary and 5 turn primary and got 80V, so i increased it to 300 to see if that would fix it, But it didn't. For the flyback 3 layers of small wire (not sure gauge pulled of something)each at 100turns insulated by tape. on the other side 5turns of plenty thick wire (again not sure gauge but its defiantly not the problem). I have ajusted the fequency but no change in output. I tried open curcuit and got 80v still. Any ideas?
Sorry for the wall of text,
-matt
