Darlington Transistors instead of IGBT
zzz_julian_zzz
Fri Mar 02 2012, 08:05AM
Registered Member #3964
Hi,,
I would like to ask if this Darlington Transistor module
300Amps/600v is suitable for drsstc applications?
fres 90khz,
Thanks in advance
Goodchild
Registered Member #2292
The short answer is no. They are way to slow. If you look at the rise and fall times for the brick they are in the uS range. I wouldn't switch those suckers any faster than 3kHz or 4 kHz and that is with a 10% guideline in regards to Fres.
zzz_julian_zzz
hahah ,. I saw also, but a thought =D thanks for the reply..
