  • Guests: 70
How to safely discharge 10kv worth of capacitors???
Cookieworks
Fri Mar 02 2012, 02:29AM Print
Cookieworks Registered Member #4229 Joined: Sat Nov 26 2011, 03:19AM
I don't know any way to discharge my capacitors without them exploding... is there any safe way?
Transformer is 7.5Kv at 30ma and the caps are 10Kv at 0.015 uF if it helps much.
Thanks!
-PS... it's a bit too late for resistors... capacitors are already charged, but when it is discharged, what size resistors should I use for bleed resistors if I have 2 parallel lines of twenty 500vac/.15uF caps (20 per string, 2 strings)?\
-Cookie
Daniel Kramnik
Fri Mar 02 2012, 02:44AM
Daniel Kramnik Registered Member #3885 Joined: Sun May 15 2011, 12:47AM
Discharging capacitors doesn't blow them up.......
If you do install a bleeder, just select some reasonable value that won't draw too much current or dissipate too much power while the HV is on, but will discharge your capacitors fast enough (how fast you want them to discharge is something that you select). I usually try to set RC to a few minutes or so.
Cookieworks
Fri Mar 02 2012, 03:07AM
Okay! Thanks! So... how do I discharge them?
m4ge123
Fri Mar 02 2012, 03:33AM
m4ge123 Registered Member #4118 Joined: Mon Oct 03 2011, 04:50PM
Short it out.
Fri Mar 02 2012, 03:40AM
E.TexasTesla Registered Member #4362 Joined: Sat Jan 21 2012, 03:44AM
If your really worried about it check the voltage at one of the individual 500v caps. It may already be dead.
You could also discharge them individually if your scared of a little spark.:-D
Turkey9
Fri Mar 02 2012, 06:14AM
Short them with the resistor....
zzz_julian_zzz
Fri Mar 02 2012, 08:18AM
15 nf capacitors do not store charge for a long time I think. maybe you could place a resistor on its terminal atleast 1k ohms would do.. This will surely discharge the capacitor, but for a longer time.. you could short the capacitor leads after it was drained by the resistors for a minute or two.
Cookieworks
Fri Mar 02 2012, 03:10PM
So just short them across the spark gap? or touch the two ends of the MMC together?
zzz_julian_zzz
Mon Mar 05 2012, 02:21AM
ow, sorry ,. it should be 10 meg ohms not 1k
Daniel Kramnik
Mon Mar 05 2012, 06:30PM
