  • Guests: 28
01/13 si2030 (62)
Boost converter
ZakWolf
Wed Feb 29 2012, 11:58PM Print
I am building a compact pistol coil gun and need a very small circuit for charging.
Sorry to ask, I have searched 4hv and Google for 2 days now and having found what i want.
I would like a boost converter that utilizes a irf510 and a 555, or just a small transformer driven by the irf510 that puts out ~400v.
Input voltage ~3-6v
At least something better then those awful flash circuits.
Im trying to do this with scrap parts i have.
Any help is much appreciated.
Thu Mar 01 2012, 12:04AM
what about a tiny ZVS with a computer PSU ferrite core rewound?
ZakWolf
Thu Mar 01 2012, 12:28AM
made with irf510's? Its gotta be 3/4" long X 3/4"wide X 1/2 tall
This Link2 or this Link2 ?
ZakWolf
Thu Mar 01 2012, 02:30AM
I used this Link2 and a 4 stage multiplier and got 200v with 6v in.
Is there any way to make output more? remove a resistor or change a value ?
Turkey9
Thu Mar 01 2012, 08:00AM
Boost converters are pretty easy and can be made very small. There are examples all over the internet of their theory. Read up on that and you'll be able to put one together that should be able to meet your needs.
Forty
Thu Mar 01 2012, 04:58PM
.75"x.75"x.5"? That's certainly a size restriction. The only things I could imagine fitting into that are a 555 driver with a camera transformer (as is or carefully rewound), a single transistor circuit like the original camera circuit, or a boost converter. A boost converter might have the best power output and will easily allow for charging regulation because they tend to use the 555 timer. two well known examples can be found at Link2 and Link2 (2nd or 3rd variants)
Marko
Thu Mar 01 2012, 05:09PM
Tom Williamson wrote ...
Yup, certainly looks like a much better idea than the infamous boost converter.
An ATX transformer will offer loads of power but a smaller one could also be used, especially if the battery pack is not able to provide hundreds of watts peak.
Marko
ZakWolf
Thu Mar 01 2012, 07:11PM
Beam tetrode wrote ...
Marko
ATX transformer as in the yellow things?
I have a mini core .5X.5X.5 that i can rewind.... very tricky
Can i power the ZVS with 6v and can i use irf510 mosfets ? wimpy little things tongue
Pinky's Brain
Thu Mar 01 2012, 08:59PM
You can buy small purpose build flyback transformers for capacitor charging by Wurth and Coilcraft, they are a couple bucks, fall right in the voltage range you want and are compact.
Some people here have used them before :
ZakWolf
Thu Mar 01 2012, 11:30PM
Pinky's Brain wrote ...
i dont want to order anything, im trying to make everything.
Thanks though
