  • Guests: 41
01/18 Noelle (43)
01/18 King_of_Junk (36)
01/18 Ixz (35)
Secondary coil coating/varnish type
Wed Feb 29 2012, 02:09PM Print
Hi,
what kind of clear varnish do you use for your Tesla coils? Do you know which type has the lowest dielectric losses at the usual TC frequencies?
Wed Feb 29 2012, 02:31PM
polyurethane varnish is what I have the best results with, I can not get hold of epoxy varnish in Denmark.
7 - 10 layers polyurethane varnish will give a nice finish.
I have also tried oil based varnishes, works just as well, but does not look as good.
Killa-X
Wed Feb 29 2012, 08:54PM
I second Mads Barnkob. I use to use poly acrylic, as it did wonders for my first coil, but i found out if you want mirror finish, polyurethane is the best. I go for the see-yourself-finish...I typically do 7-10 layers, sand with 600... repeat that 3 times, then 7-10 layers -- sand with 800, repeat 3 times... then work my way to 1500 grit, repeat 3 times, final product is mirror. Lot of work, but its worth it for me, because i love the finish :)
http://i.imgur.com/cxb1H.jpg Work in progress.
Wed Feb 29 2012, 09:45PM
Liquid Polyurethane "floor varnish' works well
and a gloss finish can be achieved
with a 'thinned' layer first to penetrate the windings
then a couple of thick layers without sanding
...need to mount the coil on a motorised device to keep the coil rotating whilst drying
OR apply many thin coats.
'Yacht varnish' gives a nice hard finish.
A thin coating is probably better than a thick one as quite a lot of 'static' charge can accumulate on a thick varnish layer and 'zap' you, not dangerous but annoying.
A thick coating does look better and provide protection against accidental 'nicks' in the wire/winding.
P.S. I don't think that the dielectric loss of the varnish is important at all.
Wed Feb 29 2012, 10:28PM
Thanks for the replies. As for the losses, I was trying to design an RF choke for a 30 MHz oscillator. The first coil which I dipped in varnish was burning hot, the second one was the same but parafin wax coated, it was better but still hot. The last one was wound with a gap between the turns and this one remains cool during operation.
So there are indeed some losses in the varnish, but if they're important at usual TC frequencies, I don't know...
Wed Feb 29 2012, 11:25PM
Dr. Dark Current wrote ...
Another factor would also be the cooling, a open coil will have a much larger surface to dissipate heat from than a varnished coil.
Tetris
Wed Feb 29 2012, 11:31PM
Minwax Polycrylic High Gloss. :D you can get it at Lowes. Killa-X was the one who reccomended it for me.
Thu Mar 01 2012, 01:15PM
For the same wire, a close wound coil will get much hotter than a coil wound with one wire diameter inter-turn space due to 'proximity effect'
Goodchild
Thu Mar 01 2012, 04:43PM
I used to use polyurethane varnish, but after working with epoxy for a while now I much prefer it over poly for a couple of reasons. First of all you only need one coat and it's a rock hard hard coating that stands up to racing sparks very well.
5013593786 5a7b962e14
Sparrow338
Thu Mar 01 2012, 06:07PM
Sparrow338 Registered Member #661 Joined: Sat Apr 21 2007, 03:17AM
I've had good luck with this stuff:
http://www.lowes.com/ProductDisplay?partNumber=147376-1149-5050080&langId=-1&storeId=10151&productId=3151089&catalogId=10051&cmRelshp=sim&rel=nofollow&cId=PDIO1
It you end up using it make sure you have a blow dryer handy for getting rid of the bubbles that form when poured. Suppose one could also de-gas it by putting it in a vacuum before pouring it.
