  • Guests: 73
Drsstc tank caps and heatsinks
Ben Solon
Wed Feb 29 2012, 02:23AM Print
A couple things:
I got 20 of these caps on eBay for my drsstc. I aim for 75nF at 6kv using 3 strings of 6. I am pretty sure these caps are good for drsstc usage, but if anyone can give their opinion it would help me. Couldn't find any good CDE caps on eBay
Secondly, for my heatsink, I have a few, but I think they may be a little too small... I will post a picture below. This is going to be run at 340vdc with a pulse current of around 250-350A. Once I find out the hard way how much these igbts can handle. They are rated for 220A Icm. I think the large sink in the back may be sufficient, but I am not sure.
heatsinks and igbts
by the way, i will be putting my construction progress on flickr, in case anyone is interested in it.
Thanks again, Ben Solon
Herr Zapp
Wed Feb 29 2012, 07:22AM
Ben -
The ICEL MWR capacitors are designed for low-current DC service. They have a polyester dielectric, which has a very high loss factor at high frequencies (e.g. they will quickly overheat when used in an RF circuit).They are metallized film construction, which is not suitable for high peak current. The exact model number you provided is not listed in the 2008 ICEL catalog, but the MWR series .15uF/1000V capacitor listed in this catalog has a peak current rating of only ~5A, compared to the peak current rating of 342A for a CDE 942C series .15uF, 1kV cap.
The peak current rating of these caps is very low. This, and the lossy polyester dielectric make them unsuitable for a TC tank circuit.
Your "3 strings" MMC could only handle ~15A, not the 350A you are looking for.
Herr Zapp
Ben Solon
Wed Feb 29 2012, 01:47PM
I guess I will just get some cde's from Dan over at easternvoltgagereasearch then. But in the meantime, I can use them just to pulse test the coil though? If I run them with just burst mode operation(single shot), they won't heat up much... Right? Or is there more than heat to wory about? Sorry, before today I haven't even heard about pulse ratings on tank caps.
ajacks504
Mon Mar 05 2012, 07:04PM
ajacks504 Registered Member #4396 Joined: Mon Feb 06 2012, 11:58PM
Save $1 a cap by getting them here:
ajacks504
Tue Mar 06 2012, 01:08AM
Also, that is one absurd electrolytic cap in that pic, what size and rating is it?
Ben Solon
Tue Mar 06 2012, 03:17AM
8200uF at 500v with low esl, esr, and hugh ripple current :p
