  • Guests: 56
Madgyver (40)
mike0t4ever (43)
Ken M. (40)
tesla500 (39)
Fabi (32)
hatto018 (40)
10/17 Madgyver (40)
10/17 mike0t4ever (43)
10/17 Ken M. (40)
Restoring a sealed 12v 7ah rechargeable battery?
Fulmen
Tue Feb 28 2012, 10:38AM
Fulmen Registered Member #3883 Joined: Fri May 13 2011, 06:30PM
Steve Conner wrote ...
you're not supposed to add acid to a battery.
Actually you can. If the acid concentration after charging is too low it is possible to readjust it, but lost acid indicates a serious problem with the cells. So chances are that anything other than a minor adjustment will be a waste of time and acid.
Tue Feb 28 2012, 12:48PM
Try to put the battery through a few charge/discharge cycles, the capacity may increase. Charge to 15 volts current limited to 0.7A, after reaching 15V wait for the current to fall to some 0.1A then disconnect the battery. If the bat doesn't draw any current at 15V, let it sit there for a while, the same applies for discharging, even when there's 0V on it when loaded, let the load connected for some minutes.
These sealed batteries are specially designed so they don't gas at 15V and you're not supposed to add any electrolyte. From what I've heard, this usually doesn't help and may kill a half-good battery.
Platinum
Tue Feb 28 2012, 12:56PM
Ahh well I guess it's easier to give it to my friend for the scrap lead...
Thanks anyway guys...
Mark-H
Wed Feb 29 2012, 10:36AM
Mark-H Registered Member #607 Joined: Tue Mar 27 2007, 10:39AM
Also be aware that a lot of SLA batteries no longer use a liquid, but a jelly or paste.
It allows them to be used "any way up."
Unsealing and adding a liquid electrolyte may be messy and explosive.
Cheers.
Alex M
Wed Feb 29 2012, 02:08PM
Mark-H wrote ...
Cheers.
Are you talking about the AGM types? arn't they usually more expensive than standard sealed lead acid types?
Mark-H
Wed Feb 29 2012, 05:37PM
Most likely... I use them on motorcycles where they have to be put in awkward places.
The price depends on the "manufacturer." Read: Whoever puts their name on it.
Cheers.
Wed Feb 29 2012, 10:18PM
SLAs are designed to have a specific quantity of electrolyte, with negligible water content.
So-called "starved electrolyte".
if you add anything to these, they break, permanently.
About the only fix I've found is to leave a solar panel connected for a week or so, with voltage limited to 15V max.
Normally this works, but if the unloaded voltage is less than 10V then it is likely not to recover.
-A
Platinum
Thu Mar 01 2012, 12:37AM
I'm going to throw it....
It's like 2 years old..
