  • Guests: 31
drsstc driver board current draw
Ben Solon
Sat Feb 25 2012, 06:01PM Print
hey, just a quick question, how much power does a typical drsstc driver board consume? say i have a driver like steves drsstc3 driver.
to power the 5v section, the current is low because it is composed of logic ic's. but what about the 15v section? i am not looking for an exact answer, i just want to know how much current ucc3732x's draw in a typical drsstc application. it probably depends a lot on the gdt however...
m4ge123
Sat Feb 25 2012, 06:25PM
m4ge123 Registered Member #4118 Joined: Mon Oct 03 2011, 04:50PM
Depends on the MOSFETs and frequency, but probably an amp or 2 RMS.
teravolt
Sun Feb 26 2012, 04:57AM
probly not more than 100ma average and 9 pulsed. the dip packages are only 400ma. usaly I add a 10 to 33 uf cap in parallel for energy storage
dude_500
Sun Feb 26 2012, 07:48AM
dude_500 Registered Member #2288 Joined: Wed Aug 12 2009, 10:42PM
You can roughly estimate it by the gate charge from the transistor data sheet. 2*F*D*Transistor_count*Q should give J/s, which is A. Although this is a low end estimate since it disregards magnetization currents assuming you are using a GDT. If you were to use discrete floating drivers, it would actually be a very accurate estimate but I doubt that is the case based on your question.
Ben Solon
Tue Feb 28 2012, 11:35PM
Ok, this is just a question in case I hypothetically use a boost converter as the 15v source. I don't even know why I thought of it though, it's a complete waste as you have to be hooked up to mains anyways... Just thought I'd ask because it can't hurt to know.
Dr. ISOTOP
Wed Feb 29 2012, 07:36AM
dude_500 wrote ...
And double that if you're using any gate resistance since half the power is lost there.
