  • Guests: 54
SG3525 fullbridge flyback driver w/ deadtime design
Acacia
Tue Feb 21 2012, 07:19AM Print
Acacia Registered Member #4073 Joined: Sun Aug 28 2011, 08:43AM
I plan on using a SG3525 to drive a fullbridge of mosfets or IGBT's switching a flyback with homemade secondary.
Because I will be using a variable deadtime to control power, would I be able to use a GDT with 2 BJT totem poles?
I havnt seen many full bridge flyback drivers, but the ones I have seen have not used a GDT, and I was wondering if this was due to flux-walking or something destructive when used with deadtime control.
Thanks
Daedronus
Tue Feb 21 2012, 09:20AM
GDT should work with a half/full bridge, but, I don't use them.
I prefer to use optocouplers + TC4420 drivers because I feel the result is more predictable, not frequency and duty cycle dependent.
That being said I have a 2.2KW 7.5V 300A EMS power supply on my desk that uses a full bridge made with 4 IGBTs and GDT to drive them.
The control IC is a SG3526.
Acacia
Tue Feb 21 2012, 10:00AM
Ok, thanks.
It's going to be a while before i get this underway, but it should be interesting
