  • Guests: 57
Madgyver (40)
mike0t4ever (43)
Ken M. (40)
tesla500 (39)
Fabi (32)
hatto018 (40)
10/17 Madgyver (40)
10/17 mike0t4ever (43)
10/17 Ken M. (40)
IGBT Amplifier
Carbon_Rod
Fri Feb 17 2012, 05:44AM
The thought of a massive amplifier is actually quite impressive.
If the frequency range is low, than perhaps one could build something like a massive continuous variable slope delta modulator.
Perhaps a few IKW75N60H3 would work if the bit rate was very close to the upper switching limits.
wink
Avalanche
Fri Feb 17 2012, 06:03PM
I thought maybe the original poster wouldn't care if it sounded like a cheesegrater tongue as for temperature compensation, couldn't you just bring the bias pot out to the front panel? cheesey
Fri Feb 17 2012, 07:22PM
I've seen some expensive handmade guitar effects that had exactly that, a temperature knob.
There is also the Zvex Nano Amp, where the user manual says: "If the power supply doesn't start, it may be too cold. Try placing it on a radiator for 15 minutes."
Experimentonomen
Fri Feb 17 2012, 07:23PM
Just to tease him a bit :P i bought 12 STE47N50 for cheap and is gonna use them for a large stereo poweramp posting 2x100WRMS at 8 ohms, 2x200WRMS in 4 ohms, 1x400W in 8 ohms bridged and 1x800WRMS into 4 ohms bridged.
I'm already working on having a 1.5kVA donut i have rewound for this project.
