  • Guests: 30
Sanchez (36)
Knarvel (13)
10/16 Sanchez (36)
10/16 Knarvel (13)
10/17 Madgyver (40)
Simpson 260 problems.
Sun Feb 12 2012, 03:22AM
when you said "it pegs" on current measurments, you mena tit went fulll scale right? the needle did move right?
sbs_2010
Sun Feb 12 2012, 03:33AM
sbs_2010 Registered Member #4392 Joined: Mon Feb 06 2012, 01:04AM
Patrick wrote ...
Yeah, it did at first, when i had it in series with the red led. But, connected how i had it in my last post, it read 17 microamps and wouldnt change no matter what scale. Which, according to ohms law, is right. It just doesnt change when i change ranges. The movement is fine, as it measures volts correctly, as compared to my other meter.
Sun Feb 12 2012, 06:59AM
Just checking,
you are using COM and POS terminals right?
sbs_2010
Sun Feb 12 2012, 01:04PM
Sulaiman wrote ...
Just checking,
Yes, except for one time I connected it to com and 50uA it read 17uA, which was correct. When connected com and POS, it still reads 17 on the scale, on 500mA, 100mA, 10mA and 1mA ranges.
Wolfram
Sun Feb 12 2012, 02:19PM
Patrick wrote ...
Sulaiman wrote ...
I agree with Steve, something in the current-shunt chain is open circuit,
most likely a resistor.
Using low voltage and a high resistance,
(e.g. 9Vdc, 1MOhm)
increase the current range until the meter reading drops
then you will know where the open circuit is.
(the resistor for the previous range) .
if there blown, then they're closed circuit--short, not open.
No, this is wrong. If a current meter is more sensitive than it should be, the shunt resistor can't be shorted. Please check your information more carefully before posting to avoid misleading others.
Here's a manual for your merer Link2 , there's a schematic on the last page. Check resistors R12-R15 and the wiring around them. The problem could also be caused by dirty switch contacts in the mode selector.
Sun Feb 12 2012, 02:31PM
I had this happen on a cheap DMM, problem was an open shunt resistor on one of the ranges.
-A
sbs_2010
Sun Feb 12 2012, 02:45PM
Ill check those resistors this evening when I get off of work. If I cant figure it out, ill post a video on YouTube and put a link here so you all can visualize whats going on
Sun Feb 12 2012, 02:53PM
Wolfram wrote ...
Patrick wrote ...
Sulaiman wrote ...
(e.g. 9Vdc, 1MOhm)
oops i thought it was the other way around, students most often killed the 260 when making current measurements. I remember that from my first EE classes.
sbs_2010
Tue Feb 14 2012, 03:28PM
Well, some resistors don't measure correctly. I think i may just change some resistors and see if it helps. This is really bugging me. I tried cleaning the switch conacts with alcohol too, and it didn't change anything, so I think the contacts are fine.
Tue Feb 14 2012, 04:59PM
sbs_2010 wrote ...
I guess if they read higher in resistance, that would cuase a greater v drop, which would incrrease the sensitivity in the current measurement.
you can get precision resistors in many values... if you really want an anaalog meter a fully functional 260 is a great one.
