  • Guests: 61
Madgyver (40)
mike0t4ever (43)
Ken M. (40)
tesla500 (39)
Fabi (32)
hatto018 (40)
10/18 seveerz (69)
10/21 ben106 (40)
10/22 803 (2025)
VTTC power regulation by heater voltage
Thu Feb 09 2012, 08:08PM Print
What do you think about regulating the output power of a VTTC (or a similar oscillator) with a *directly heated* tube, by changing the heater voltage?
Marko
Thu Feb 09 2012, 10:05PM
Dr. Dark Current wrote ...
IIRC, if heaters of oxide cathode tubes are underdriven, they tend to get destroyed quickly by ion bombardment and I suspect similar fate would await tungsten cathode tubes too at perhaps a bit slower rate, if they are devoid of their protective electron cloud.
It would also waste large amounts of power without even enabling audiomodulation or suchlike. I'd just use a tetrode instead of punishing tubes that way.
Marko
Patric
Fri Feb 10 2012, 09:51AM
Patric Registered Member #2899 Joined: Wed Jun 02 2010, 06:31PM
I use this circuit, and it is very reliable.
1328867448 2899 FT133906 Tesla811adefall
Fri Feb 10 2012, 10:21AM
Marko, I know about the oxide cathodes which are used in indirecly heated tubes. That's why I wrote directly heated tubes, which use thoriated or carbonised tungsten filaments.
Patric, the idea of this was to decrease regulating power (less losses in the TRIAC) and to keep smooth plate voltage for the tube, so the sparks don't buzz.
