  • Guests: 46
Sanchez (36)
Knarvel (13)
10/17 Madgyver (40)
10/17 mike0t4ever (43)
10/17 Ken M. (40)
Halfbridge?
Platinum
Fri Feb 03 2012, 05:42PM
Alex1M6 wrote ...
Patrick wrote ...
Does everyone else see Pink block space? or is my computer puking from a virus?
Sounds like a problem with your graphics card, or something is overheating.
The right side of the ZVS I have a 7.5v zener and it gets very hot compared to the 18v zener.
No it is the forum, it can't use mybb.
But will there be any reason to build a halfbridge, and forget the ZVS?
Platinum
Sat Feb 04 2012, 12:13AM
Hmm I was just "experimenting" with the air gap on a flyback I use a large flyback when driving it with ZVS, anyway the air gap is less than say 0.5mm's big, I widened it to about, 3mm and the output voltage and current was massive very hot and very long arc, normally the arcs are impressive without doing this. The flyback arcs to air, I need to put it in oil now, I'm using 8+8 TURNS!!! normally I use 4+4 to get best output!
Maybe the flyback was at resonance.
