  • Guests: 57
Sanchez (36)
Knarvel (13)
10/17 mike0t4ever (43)
10/17 Ken M. (40)
A few questons about my vttc
Luceš
Sun Jan 29 2012, 11:18PM Print
Luceš Registered Member #4108 Joined: Sun Sept 25 2011, 11:43PM
I have a couple of random questions about my gu-81m vttc...
How come when I turn it on and it hasn't been run for awhile the sparks are about 1 inch and then after it has run about 15 sec the arcs grow to upwards of 20 inches?
My science teacher wants me to run my vttc for the class, and I was going to touch the sparks from it, is there anything bad that could result from that?
thanks
teravolt
Mon Jan 30 2012, 02:34AM
It is probly not a good idea to tuch the spark directly and not at all if you dont know what you are doing. The tube needs a short warm up time of 2-5 min. see if that works
Luceš
Mon Jan 30 2012, 03:47AM
How come other people touch the sparks if it's not safe? I have held on to a knife and arced to my sstc but those were like 3 inches.
Dr. ISOTOP
Mon Jan 30 2012, 03:52AM
NO NO NO it's never safe to touch the sparks from a Tesla coil.
Skin effect, nerve insensitivity, blah blah blah. Bottom line is, it could still kill you, and you should not do it without a Faraday suit.
Mon Jan 30 2012, 10:19AM
Maybe your resonant capacitor is heating up and changing its capacitance. Or as other said, it takes a few seconds for the tube heater to heat up, but you should always pre-heat the tube before applying plate voltage.
Mon Jan 30 2012, 11:17AM
Other people do things like this Link2 but that doesn't mean that it's safe.
I'd sooner touch the sparks.
Luceš
Mon Jan 30 2012, 12:39PM
Thanks!
My friend Lukas said there is nothing to it.so when I say I'm going to do it I turn it on the sparks are so narly I chicken out. But thanks for warning me! As for the filament I have a pre-heat resister, I let it run 30 secs, then after I switch it and let it run for another 30 secs before applying b+
