  • Guests: 56
Need Tesla coil help not working properly
Littlecoiller2012
Sat Jan 28 2012, 09:34PM Print
Littlecoiller2012 Registered Member #4373 Joined: Sat Jan 28 2012, 08:44PM
Hello there this is my first time posting on this forum.
The problem im currently having is that my toroid will not create a spark with out putting a discharge terminal (i use a nail on the toroid) that arc to the same ground that my secondary is connected too. The maximum spark that i have been able to achieve is 8 inch but normal i can only get multiple streamers of 5-6 inchs in distance to the object im targeting. Id like to try and understand why i see videos on and tesla coils arcing on there own with out a discharge terminal added to there toroid and can shoot stearmer into the air its almost like my tesla coil cant discharge into the air. I have tunned my coil to the best i coild by moving my tap on the primary all around to have the best output. Please help
To start off im using this set-up currently
Capacitor: 20 nano-farad salt water capacitor
Transformer: 10 000 volts 23 mA x 2 ( ran in parallel)
Series spark gap 5 of them (richard quiks)
toroid : alumminum duct 4 x 15 16.6 pF
primary: 12 turns 3/8 copper pipe (tapped at turn 10)
secondary: 1016 turns 20 inchs high
Visual help i put a few picture to try and better understand i show a picture of the arc that is shooting out of my discharge terminal id like to have my toroid shoot stearmer out a random dirrections if any more info is needed id like to get my coil to be have 18inch streamers.
All the help is appreciated
1327786447 4373 FT0 Tesla Coil 030
1327786447 4373 FT0 Tesla Coil 043
Littlecoiller2012
Sat Jan 28 2012, 09:38PM
Here is more pictures if this helps
1327786710 4373 FT133351 Tesla Coil 035
1327786710 4373 FT133351 Tesla Coil 353
teravolt
Sun Jan 29 2012, 03:12AM
I think you need another case of beer, but seriosly I think it needs more capacitance. With more capacitance you could reduce primary inductance. Beer bottles have more surface erea than those jugs. Reduce the length of wire between your caps and primary.
Littlecoiller2012
Sun Jan 29 2012, 04:17AM
Thanks ya iv reduced the lenght of wire and made the set up much cleaner. Still having the problem that it would discharge with out a discharge point. do you think it has to do with my wine bottle capacitors iv built im not sure how efficent they are but i used my meter to read them having 20nF. This is a spark gap tesla coil if you didnt notice. How can beer bottles have more surface area
m4ge123
Sun Jan 29 2012, 05:46AM
m4ge123 Registered Member #4118 Joined: Mon Oct 03 2011, 04:50PM
The resistance of your caps may be hurting the performance. See if you can put aluminum foil on the inside.
Since your meter has a capacitance function, I assume it has a frequency function too. If so, you should check to make sure the resonant frequencies of the primary and secondary are the same. See the TC tuner here Link2
Tetris
Sun Jan 29 2012, 09:10PM
But discharging without a discharge point is cool! You make lichtenberg-like figures in the air! At least your coil is arcing. Mine doesn't do a thing without a grounding stick. The NST itself produces a longer spark :/
Maybe try making the discharge point longer?
m4ge123
Sun Jan 29 2012, 10:47PM
I think he meant his TC won't make any sparks without a discharge point close to RF ground.
Littlecoiller2012
Sun Jan 29 2012, 11:29PM
m4ge123 wrote ...
Ya i meant to say that iv gotta use a nail attached to my toroid by taking a peice of tape and stick it on my toroid so that i can discharge it with out it my coil doesn't seem to want to work no streamers are produced also streamers are more effective to rf ground. I dont understand how other peoples coil work with out this discharge terminal. any advice?
