  • Guests: 42
420V from 12V
Tetris
Wed Jan 25 2012, 04:11PM Print
(I'm on the school computer, apparently Tesla Coils are not considered weapons, and horse hooves are R-Rated...)
Anyways I had built a little 555 driver for a little transformer built in a electronics set I had got a while back (the transformer, through a little math, had approximately a 1:30 turn ratio). Using a 9V and a pot for one of the resistors, I was able to get 1.5V across the primary, and a range of 23V-57V across the secondary. I tried to get it to as high a voltage as possible. So I then grabbed a 12V source (which was a power brick that was stripped so far back I couldn't tell the polarity) and plugged it into the 555 and then smelled the magic smoke. Then I put the 12V through a push button switch. Pressing the button as fast as I could (because I don't have mosfets) I watched my meter read only 2V. Then I was curious to see if this was really the case, and touched across the secondary, and I got a (calculated) 420V through my fingers :/ But I was happy to get 23-57V out of the driver. Unfortunately I drained 3 9V through the process... they still have a little voltage but barely enough to power the circuits that I have to build for school (such as this 4511 counter one I have beside me)
TeslaGirl
Hon1nbo
Wed Jan 25 2012, 05:16PM
If you do something similar again, I woulduse a relay which is usually polarity independent as a fast acting switch (I think tesladownunder has a great example of this on his site, though right now I can't grab the link).
